Insignia ns50d510na19 tp.ms3553.pc906 power schematic
  • oddbondboris
    • Jun 2011
    • 10
    While diagnosing one of these boards with no backlight voltage i came across a Chinese schematic fragment with a Haier logo in the top corner
    it nearly perfectly matches this tv board down to the component designators
    thought i'd post it here as there is little info out there on these all in one boards and obviously no schematics from insignia
  • neilc6
    • Nov 2015
    • 1550
    Re: Insignia ns50d510na19 tp.ms3553.pc906 power schematic
    If you have no backlight, you likely have bad backlights especially with that model. The protection circuit shuts down the backlights when the sensed voltage is not within expected range. If you put your multimeter probe on the backlight connector, you should see it spike when the TV is first turned on before protection kicks in.
    • oddbondboris
      • Jun 2011
      • 10
      no spike, i already replaced the backlights because i've seen so many of these with bad backlights before and forgot to check
      these backlights light if provided voltage but thanks, don't want someone to see this thread and think that they have a bad board when it's just the much more common leds
      • Traktorist3d
        ASUS VivoBook T3300 schematic & boardview, fragment of connecting the TOUCH to the Motherboard and multi-controller
        by Traktorist3d
        Comrades, I have a task for a DIY project to connect the display from VivoBook T3300K to a separate DIY device. There are no problems with eDP, I found a scaler for the ATNA33 OLED matrix, but with the touchscreen it’s more difficult, I need a diagram to understand how it is connected and works in order to try to connect the touchscreen to another device via USB
        07-20-2024, 07:33 AM
      • TinkerTron
        Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
        by TinkerTron
        Hey everyone,
        I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
        Instead, here's what's been bugging me so far:
        The schematic...
        03-06-2025, 02:03 PM
      • atunguyd
        Acer x163w Monitor PSU schematic
        by atunguyd
        Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
        The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
        03-05-2025, 02:08 PM
      • Thetechdude
        MSI Ventus RTX 4080 16G Broadview schematic needed
        by Thetechdude
        Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
        I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
        Thanks.
        07-15-2025, 11:15 AM
      • ianpoultonknights
        Zenbook Flip 15 UX562AI schematic
        by ianpoultonknights
        Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
        06-26-2025, 02:41 PM
