Westinghouse LCM22W2 Help (DAC-19M009)
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Westinghouse LCM22W2 Help (DAC-19M009)
    Originally posted by buzzbolt
    I am working on the motherboard of the same monitor and all this info is really helping. I have 3 bulging caps. I am hoping this forum will help me figure out what I need exactly and how to replace it.
    The picture of the motherboard is a bit small so we can't read the caps, but you can.
    List the uF, V, height, and diamter for each cap and its location.
    For example
    C123 - 1000uF, 16V, 10mm height, 16 mm diameter
    Also, list where you live so we can suggest a suitable supplier.
    To replace caps, you unsolder the old cap and solder in the new cap (make sure to get the polarity correct).
    --- begin sig file ---
    --- end sig file ---
    • buzzbolt
      • Jul 2010
      2 of them are: Capxon 21mm high x 10.2mm diameter / 1000uF / 25v
      1 is: Capxon 21mm high x 13.2mm diameter/ 2200uF/ 10v
      I live in Waco Tx.
      76705
      • retiredcaps
        • Apr 2010
        • 9271
        You might as well replace the other caps in between the heat sinks as they are likely been subjected to a lot of heat from the transistors.
        In fact, most here will suggest you replace all the caps due to age, heat, and possibly suspect brands.
        Since you live in the USA, most on this forum like ordering from digikey or mouser (or here).
        The part numbers for digikey are
        UCC KMG 10.00mm x 20.00mm
        http://search.digikey.com/scripts/Dk...me=565-1311-ND
        - note this is one of the few caps that fit the dimensions you list above
        Panasonic FM 12.5mm x 20.00mm
        http://search.digikey.com/scripts/Dk...name=P12357-ND
        • rseery
          • Aug 2010
          Originally posted by Doward
          Ok, so provided my lead spacing is correct, here's what I'm looking at ordering:
          (1) 400v 120uF - Still searching... - United Chemi-con makes the exact sized one I need, but in 350v!
          I am doing the same repair. What did you finally decide on for the 400v 120uF? Or did you decide to leave it alone? Also, if you have completed the repair, did it work?
          Thanks for all the work and for documenting it here.
          Bob
          • rseery
            • Aug 2010
            Thanks for all the info on this repair!! I ordered the exact parts list from this thread and my monitor is working again!!!
            • tloftus
              • Aug 2010
              • 9
              #26
              Sorry for bringing back this old thread, but I have this same monitor and power board. I have replaced all 9 capicators with the parts listed earlier in this thread but still have the same problem. The monitor will come on, display momentarily (1-2 seconds) and then the backlight will shut off.. can anyone help troubleshoot this issue?
              Thanks,
              Tom
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                We need a baseline of your knowledge and equipment.
                Do you have a multimeter? Do you know how to use it? Do you have any electronics knowledge?
                As a starting point, see
                https://www.badcaps.net/forum/showthread.php?t=10419
                You can post your test results and what you have tried. If none of the suggestions work, we can make more.
                PS. Post pictures of your boards.
                • tloftus
                  • Aug 2010
                  • 9
                  #28
                  I will start there and get back to you, thank you.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Thanks,
                    Tom
                    More information would also be helpful. For example, does the sound also go out? Can you see the image if you shine a bright light on the screen?
                    When you are taking pictures, include one of the inverter.
                    PlainBill
                    • Doward
                      • Jun 2010
                      • 18
                      #30
                      For the record, I am JUST NOW getting around to making this repair I'll let you all know how it goes.
                      • truep
                        • Aug 2010
                        • 373
                        I sold a sanyo tv to a guy who called back and said he had a similar problem.
                        I brought it back and ran it for 2 days with no problem, I even took it outside in 100 degree weather and all was well. I went to his house and it worked fine until his AC kicked in. Turned out it was getting 95VAC! Check your mains voltage.
                        • Doward
                          • Jun 2010
                          • 18
                          #32
                          Replaced all 9 caps - complete success! Now rocking dual 22" screens for my main setup! Need to keep my eyes open for more bad LCDs
                          • raven1708
                            • Nov 2010
                            #33
                            I just got one of these boards in to repair. The main problem i am having is that it seems that he took it to someone else for repair first and they removed two caps from the board and never replaced them. I have no way of finding out the values of them and was wondering of someone could look on theirs that they are working on. Their locations are CE105 and CE109. Thank you
                            • Wrog
                              • Oct 2009
                              • 472
                              #34
                              If your power supply board looks anything like the one attached to post #1, point out which ones are reference designator CE105 and CE109. Then someone can likely match up the can size with the proper values.
                              • alexanna
                                • Mar 2010
                                • 1346
                                #35
                                post a pitcure of your board and point out CE105and CE109
                                Al
                                • tloftus
                                  • Aug 2010
                                  • 9
                                  #36
                                  Ok, I am finally getting back to this.. I have a Westinghouse LCM22W2 with the DAC-19M009 power / inverter board. The display comes on for 2 seconds and then the backlight goes out -- the image is still visible, just no backlight. I replaced all 9 capacitors on the board with Panasonic ones from Digikey and still have the EXACT problem. I do not have a meter to check the capacitors, I am pretty good with a DMM if instructed on what to look for. I have attached a photo of the front and the back of my board. Thanks in advance for any help that you can provide.
                                  Tom
                                  • Wrog
                                    • Oct 2009
                                    • 472
                                    #37
                                    Assuming the Panasonics you used are new FM series (that's what they look like to me), you won't need a meter to check to see if they are good. Retiredcaps has an excellent thread on things to check when it comes to "2 seconds to black" problems.
                                    • tloftus
                                      • Aug 2010
                                      • 9
                                      #38
                                      Here are some results if they help:
                                      Transistors (U106 / U103): All the readings start in the 5-10k ohm range and then begin climbing. Tested all 6 combinations of readings with similar results.
                                      All tests done in circuit.
                                      Mosfets (D101, D102): All the readings behave in the same manner.. they start in the 0-5k ohm range and then either begin climbing or falling depending on the pin combination. I can give exact results if someone can tell me exactly what I'm looking for here.
                                      Fuse (F200): Continuity exists.
                                      Transformers (T200, T201): These have 11 pins (7 on one side, 4 on the other) on each of them.. I'm not sure how to read them as I get no resistance reading on any combination I try. Some of the leads are covered in goop though and I dont want to try to remove that and mess something up until I know what I'm looking for.
                                      CFL Bulbs - No spare to test with.
                                      Without some specific instruction this is about the best that I can do. If there is anything specifically I can check please let me know. Also I failed to mention that I did not replace the large 400V 120UF capacitor when I did the other 9 smaller ones.
                                      Thanks,
                                      Tom
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        Thanks,
                                        Tom
                                        It's unlikely the large capacitor is responsible for this problem.
                                        I've marked up the picture of the bottom of the board. The resistance of the transformer secondaries should be tested by measuring from S1 to S1a and to S1b. Also measure from S2 to S2a and S2b. Use a needle to make contact with the solder pads At S1a, S1b,etc. Closing the hole with hot melt glue is a good idea.
                                        Measure the voltages at R1, R2, R3, R4, V1, and V2 while the backlights are on.
                                        Try to determine if a CCFL is broken by unplugging 3 of the CCFLs, then turning on the TV. If the display flashes, turn the TV off, then unplug the first CCFL and plug in the next, Turn the TV on again and see if the display flashes. Repeat for each CCFL. If there is no flash from a particular CCFL, it is either defective or there is a wiring probblem.
                                        PlainBill
                                        • tloftus
                                          • Aug 2010
                                          • 9
                                          #40
                                          S1 -> S1A = 358 ohms
                                          S1 -> S1B = 356 ohms
                                          S2 -> S2A = 357 ohms
                                          S2 -> S2B = 357 ohms
                                          The next thing I did was your CFL test and what I found was interesting.. one at a time each of the bulbs displayed 2 seconds of light except for one, the one labeled CN2. It, by itself, did nothing.
                                          Also I failed to mention but there is a faint but audible noise coming from the area the "failing" CFL wires lead to (I have not yet disassembled any further into the CFL or LCD assembly). When I disconnect the "failing" CFL wires (leaving the other 3 connected) there is a louder noise that appears to be coming from the power / inverter board. Either from one of the two transformers you had me check resistances on or the transformer near the large cap / power cable.
                                          Thanks for your help in troubleshooting this.. I REALLY appreciate it.
                                          Thanks,
                                          Tom
                                            ALIENWARE Area-51 R4 i7-7800X Specification for Upgrade or Repair
                                            This specification for the ALIENWARE Area-51 R4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Area-51 R4 boardview and Area-51 R4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE...
                                            09-12-2024, 03:28 PM
                                            ALIENWARE Area-51 i7-5820K Specification for Upgrade or Repair
                                            This specification for the ALIENWARE Area-51 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Area-51 boardview and Area-51 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE Area-51...
                                            ALIENWARE Area-51 R2 i7-6900K Specification for Upgrade or Repair
                                            This specification for the ALIENWARE Area-51 R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Area-51 R2 boardview and Area-51 R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE...
                                            Alienware Area 51m R2 Notebook Specification for Upgrade or Repair
                                            This specification for the Alienware Area 51m R2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Area 51m R2 boardview and Area 51m R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                            09-07-2024, 02:00 AM
