QUICK QUESTION! P&F 55PFL7900 F7 - Is this panel damage?
+ More Options
Posts
  • triplefour
    • May 2014
    • 1747
    i have this question every so often when looking at a TV.
    it LOOKS a lot like panel damage,
    but could it be explained by something else?
    could the mainboard or tcon possibly cause the vertical separation of the image seen in the video?
    or could it be something on the panel driver boards that can be repaired?
    i would love to hear what others think based on their experiences.
    https://youtu.be/RSJsiJ8Z8Qc
    thanks for playing!
    Don't fear the repair...
    • 12104
    • U.S.
    Re: QUICK QUESTION! P&F 55PFL7900 F7 - Is this panel damage?
    Tape cut-off method might give you a good picture.
    • triplefour
      • May 2014
      • 1747
      Can you please explain more about this tape cut off method or link to where it is explained? Thank you!
        • 12104
        • U.S.
        https://www.youtube.com/results?sear...+piece+of+tape
        • triplefour
          • May 2014
          • 1747
          thanks. i have never done this repair. i will try it and report back. neat!
          • triplefour
            another QUICK QUESTION! LG 55UH615A - Is this panel damage?
            by triplefour
            im still waiting to hear back from the guy whos tv i posted a similar question about earlier. so i havent tried the tape cut off method on that tv yet, or any tv for that matter.
            in the meantime, i bought this tv off of a guy who didnt want to pay me to fix it. i got it for 10$ i told him it was possible i could fix it with some tape but maybe he didnt believe me...or just didnt want to bother. anyway its mine now, to hopefully fix and sell!
            could this be a similar problem? i think it would be a cool idea to have a database of different examples of panel damage videos...
            07-08-2022, 10:56 PM
          • howardc64
            LG 49UJ6500 LCD panel lighter band that goes away
            by howardc64
            49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
            Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
            02-19-2023, 12:13 AM
          • triplefour
            SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
            by triplefour
            TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
            tcon is built into mainboard.
            Only one cable goes to panel boards.
            there is a cable from one panel board to the other that links them.
            cost cutting measure that results in us having harder time to diagnose.
            removing the link to the second panel board allows TV to stay on with stable backlight but no image.
            used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
            07-28-2022, 07:59 PM
          • Storyteller12
            QN55Q60R Service Menu Panel Help
            by Storyteller12
            I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
            I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
            I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
            the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
            01-13-2024, 01:57 PM
          • maneatingmonkey
            Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
            by maneatingmonkey
            I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
            There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
            03-27-2024, 07:17 AM
