Capacitor change for LED TV PSU
  • unimatrix93
    • Oct 2021
    • 360
    • Magyarország
    I have a Hisense LED TV with a faulty PSU.
    Found out one of the caps on the PSU is bulged and it makes a chriping noise, while the screen flashing a white line in sync with the noise.
    Now I want to replace that cap which is a CD288HC and it's most probably a 25V 330uf. I say most probably because the cap print only says the voltage, not the capacitance. Also, I measured it's size and it corresponds with the datasheet.
    Now I need to find a replacement cap, in fact 4 because maybe I should change all of them.
    Now I cannot find one with the same values anywhere, which is also in stock so I don't have to wait for weeks.
    I found however a 25V/470u one which is also low ESR and imp. rated.
    Would it do the job? I know higher voltage rating is okay, but I don't know if higher capacitance is okay too?
    The other option is 35V/330uf but they are not low ESR/imp rated.
    What should I do guys?
    Thank you!
  • nortnil
    • Jul 2008
    • 40
    Re: Capacitor change for LED TV PSU
    Generally speaking you're safe going up on both voltage and impedance. In your example the 25V/470uf will work.
    • unimatrix93
      • Oct 2021
      • 360
      • Magyarország
      That's good to know.
      Someone recommended me going with low ESR caps for TV PSU-s.
      So that's what I ordered. Hope they will do the work.
      • MORETTIGIAN
        Capacitor detached from PCB – RTX 2070 Super Founders Edition
        by MORETTIGIAN
        Title:
        Description:
        During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
        I did not notice it detaching, so I am unsure of its original location on the PCB.
        Procedure performed:
        - Removed backplate
        - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
        - Reapplied thermal compound
        - Reassembled card
        Observed behavior after reassembly:
        - GPU powers on and operates normally under...
        09-18-2025, 12:14 PM
      • Prolog
        RTX 3080 FE Identifying capacitor
        by Prolog
        Hi people, I hope this is the correct spot to post this, I'm new to the forum.
        I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
        I hope these photos make it clear which component I am referring to:
        (yes, the soldering is a bit botched from removing the blown one, I know)
        I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
        12-01-2024, 08:27 PM
      • chth96
        If I replace with inferior capacitor, Is it No harm to other IC components at all?
        by chth96
        I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
        Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
        It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
        So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
        I know that these capacitor will not last as long as nichicon capacitor...
        12-22-2023, 04:34 AM
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
      • chth96
        Should I replace polymer capacitor?
        by chth96
        a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
        I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
        Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
        Is this ESR value of polymer capacitor correct?...
        11-18-2022, 04:22 AM
