Capacitor change for LED TV PSU
+ More Options
Posts
  • unimatrix93
    • Oct 2021
    • 343
    • Magyarország
    I have a Hisense LED TV with a faulty PSU.
    Found out one of the caps on the PSU is bulged and it makes a chriping noise, while the screen flashing a white line in sync with the noise.
    Now I want to replace that cap which is a CD288HC and it's most probably a 25V 330uf. I say most probably because the cap print only says the voltage, not the capacitance. Also, I measured it's size and it corresponds with the datasheet.
    Now I need to find a replacement cap, in fact 4 because maybe I should change all of them.
    Now I cannot find one with the same values anywhere, which is also in stock so I don't have to wait for weeks.
    I found however a 25V/470u one which is also low ESR and imp. rated.
    Would it do the job? I know higher voltage rating is okay, but I don't know if higher capacitance is okay too?
    The other option is 35V/330uf but they are not low ESR/imp rated.
    What should I do guys?
    Thank you!
  • nortnil
    • Jul 2008
    • 40
    Re: Capacitor change for LED TV PSU
    Generally speaking you're safe going up on both voltage and impedance. In your example the 25V/470uf will work.
    • unimatrix93
      • Oct 2021
      • 343
      • Magyarország
      That's good to know.
      Someone recommended me going with low ESR caps for TV PSU-s.
      So that's what I ordered. Hope they will do the work.
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • chth96
        by chth96
        12-22-2023, 04:34 AM
      • JohnsonJ
        Allen&Heath XONE92 DJ mixer repair
        by JohnsonJ
        Hello everyone.
        I'm having issues with my DJ mixer, and after taking it apart and checking everything out, it seems that I need to replace 2 rotary potentiometers for the filter, and that the PSU has some caps burned. Hopefully these 2 fixes will solve my issues.
        The potentiometers I will just replace (hopefully the repairman I spoke with will indeed send me the spares, in case he doesn't, I'll update here if we can find a suitable replacement), but for the PSU caps I'd kindly ask you forum members, if anyone could help guide me in the right direction. I'm having difficulty...
        12-12-2020, 11:19 AM
      • goodpsusearch
        Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
        by goodpsusearch
        Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
        First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...
        05-05-2024, 02:04 PM
        Sacon FZ revival experiment
        by momaka
        So after using capacitor bungs to repair the rubber feet on two laptops, shown here:
        https://www.badcaps.net/forum/showpo...&postcount=548
        … and here:
        https://www.badcaps.net/forum/showpo...&postcount=585
        … I was inevitably left with some paper rolls and cans from the Sacon FZ capacitors I “sacrificed”.
        The paper rolls from these Sacon FZ caps looked absolutely bone-dry. The idea then occurred to me: what if I put a few drops of water on there? How (if at all) would that affect these already-failed capacitors?...
        01-26-2022, 08:43 PM
