zenith plasma Z50PX2D
  • pete g
    • Jan 2010
    • 20
    Hi, problem is 6 vert lines the width of the screen. Lines are filled with round white dots, also static in sound when dots vary. Anyone know of this problem?
  • R_J
    • Jun 2012
    • 9624
    Re: zenith plasma Z50PX2D
    Why not post a picture of the problem. it could be anything if it effects the sound as well as the picture, it could be the input source connector is loose,
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • pete g
      zenith plasma tv. the model is Z50PX2D.pix problem
      by pete g
      hi, i have a zenith plasma tv. the model is Z50PX2D. i really love this tv. as of late its coming on with 6 vertical lines of white dots. they flicker, the audio seems to affected also with static sounds. all other aspects of the pic are good. i have good color, and no other problems with picture. can someone help? thanks.
      06-18-2022, 12:10 PM
    • xNOTx
      Verticle lines on Samsung PN42A400 Plasma TV
      by xNOTx
      Hello 👋 I have a tv with these red lines. I've tried cleaning and re-seating the ribbon cables but no luck! Tried all 4 on the LJ92-01485 board and on the bottom of the panel. Do you guys think it's the board?|
      [Edit] I don't know why the thumbnails aren't linking to the full images, but here is the gallery. https://postimg.cc/gallery/WZcFzyf
      04-30-2024, 04:22 PM
    • afex
      Samsung Plasma TV with vertical lines (model PN50B430P2D)
      by afex
      This is my 2nd broken TV I'm trying to fix and haven't been able to figure out... currently going without any working TVs so am hoping to be able to fix one..
      This Samsung PN50B430P2D Plasma has this big block of vertical lines which will fade in shortly after turning the TV on. The lines will sometimes flicker a bit or fade in/out and sometimes it just stays present. The length of time it takes them to appear varies, sometimes its a few minutes and other times it appears immediately after powering on.
      I have attached an image of the TV with these bars displaying....
      11-08-2021, 09:23 PM
    • Stanley1843
      Screen Display Vertical Multicolor Lines
      by Stanley1843
      Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
      06-29-2024, 11:54 AM
