samsung le37c630k1w standby lights but no power on
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    hi to all
    at first the problem of tv is has light on standby but if i press or fron the remote control or fron the power button to be on it retains on standby
    on the above tv i have download the service manual of power supply bn44-00339b from electrotanya
    when i remove the plug cn802 from mainboard i measure in pin 1,3,5,17 12.5 volt
    on pin 16 5.2 volt and on the pins
    11, 13, 14 4 volt maby i have problem here i think must be 5 volt right ?
    and on the plug cni801 i can measure on the pins 10 ...14 24 volt and the backlight is on normal
    but if i connect the mainboard with the plug cn802 the voltages on the pins 1,3,5,17 are not steady variable from 0 -12 volt the same happens and on the pins 11,13,14 variable from 0-4 volt
    can anybody tell me if the problem is on power supplu or mainboard ?
    thanks in advance
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: samsung le37c630k1w standby lights but no power on
    Looks like you may have a mainboard problem.
    • Xristakis795
      • Mar 2021
      • 162
      • Greece
      from your exprerience something is short on the minboard and causes this problem or the better is to find used mainboard from ebay ?
      and on the pins which must have 5 volt and measure 4 volt you thinks i havent problem ?
      • nomoresonys
        • 12307
        • U.S.
        check the voltage regulators on mainboard.
        • nomoresonys
          • 12307
          • U.S.
          did you try unhook the cable from mainboard to tcon, then see if those voltages are still unstable?
          • Xristakis795
            • Mar 2021
            • 162
            • Greece
            yes sir i did this the same result
            you mean the regulators of the mainboard right ?
            i will measure and i will write about
            as about as the voltage of power supply instead 5 volt i have only 4 volt on the particular pins wich tell you above do you think is this the reason to cause the problem ?
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8342
              Missing PSon is most of the time a problem with the mainboard’s main IC. Nothing much you can do about it besides replacing either the board or the IC.
              • Xristakis795
                • Mar 2021
                • 162
                • Greece
                for what particular ic do you mean sir ?
                and the voltages when the plug of power supply connected to the mainboard
                which variable from 0 - 12volt its not mean something like short on the main ?
                • nomoresonys
                  • 12307
                  • U.S.
                  voltage testing: https://www.youtube.com/watch?v=ocqnqmBxiqY
                  • Xristakis795
                    • Mar 2021
                    • 162
                    • Greece
                    thanks
                    i have seen this video
                    its very good
                      09-07-2024, 05:50 AM
                    • ChristianBr01
                      LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                      by ChristianBr01
                      I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                      The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                      What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                      04-23-2025, 01:48 AM
                    • Kaar3l
                      Samsung QLED QE65Q7FNAT only standby light
                      by Kaar3l
                      TV: Samsung QLED QE65Q7FNAT
                      PSU: BN4400940A
                      MB: BN94-12832K
                      I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                      09-24-2024, 01:35 PM
                      09-06-2024, 11:40 PM
