Pioneer PRO-1150
  • Sparkitus
    Wire Junkie
    • Jun 2010
    Pioneer PRO-1150
    Ready for a head scratcher?
    My PRO-1150 plasma has a strange red snow effect. It only happens on pixels that are bright, and intense, no matter what color is showing. Dark areas of the image are still perfect even if it is a dim white light showing.
    There is also a small amount of temporary image retention of the red snow. Meaning, if a bright area goes dark, a ghost of the red snow is left in the darkened image.
    With no image showing, just a blank source, there is no flickering, snow, or anything. I've tried the built in screen refresh ( white bar moving left to right)
    with no luck.
    Any ideas?
  • el3ctroded
    • Nov 2008
    • 198
    Re: Pioneer PRO-1150
    See if this helps: Use a good fan and blow on the back of the panel in one area at a time. Does it get better? At what area that you blow the air on does it help the most?
    I had a plasma that did that when it's Ysus board got to temperature. Added a fan all was Ok. So far been a month without any issues.
    That said, if you do have a heat issue and it's related to the Ysus board or Zsus board, it could be caused by drying-out heatsink compound.
    Also check the power supply for bulging caps. It may be caused by Vs voltage issues. Vs should be somewhere around 170V-210V, depending upon your screen. Your power supply board may say what range is Ok on it somewhere.
      HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
      This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
      09-12-2024, 02:20 PM
    • Jaime Morillo
      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
      by Jaime Morillo
      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
      The TV was stuck on the logo and I couldn't access the update menu.
      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
      The image result was good, but the image is inverted.
      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
      08-18-2025, 11:38 AM
    • x_orange90_x
      Pioneer PN50951-22U Backlight On, No Image
      by x_orange90_x
      I get backlights that stay on not there is no image. The tv does not automatically power on when plugged in either which I generally see happen when there is a fault. It responds as it should to the power button.
      I checked the test points on the TCON and I have proper voltages except for at 1P15V. I don't know if that is supposed to be 15V or 5V, but either way I only get 1.134V on that point. I have 12V, 8V, VCC, and a small amount on the CKV point.
      I tried heating up the SoC on the main board but that made no difference. Disconnecting either ribbon from the TCON also...
      06-01-2024, 08:55 PM
    • oHardax
      Gigabyte RTX 2060 Super 8GB GV-N206SWF2OC-8GD not showing image
      by oHardax
      I recently got this video card that turns on but not in the image, it has all the voltages, but it lacks a voltage of 1.1v, all the others have 12, 5, 3, 1.8. I've already replaced the GS9216 but it's still in the same situation, could anyone give me a tip on what I can try?
      02-24-2024, 02:02 PM
      HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
      This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
      09-06-2024, 10:56 AM
