Technika T32HD-278-17 (VESTEL)
  • unimatrix93
    • Oct 2021
    • 343
    • Magyarország
    Hello everyone!
    My crappy Technika TV has a flashing red light symptom. Black screen, Voltages looks good.
    Does anyone have the EEPROM bin file for this model?
    Technika T32HD
    MB: Vestel 17MB140
    Panel: VES315WNDA
    Thank you!
  • yokoono
    • Apr 2010
    • 481
    Re: Technika T32HD-278-17 (VESTEL)
    You can try the repair software. It's for the stick.
    • unimatrix93
      • Oct 2021
      • 343
      • Magyarország
      Thank you!
      I will try it tomorrow and report back with the results.
      • unimatrix93
        • Oct 2021
        • 343
        • Magyarország
        I tried the reset software, but sadly nothing happened. The blinking is still there and nothing got written on the stick. I formatted it to fat32.
        Should I try to flash this bin file directly to the eeprom?
        • yokoono
          • Apr 2010
          • 481
          1. Unzip and put the files on the stick
          2. Unplug the TV and insert the USB stick
          3. Press the OK key on the remote control and press and hold
          4. Plug in the TV.
          5. When the stby LED on the TV flashes quickly, the OK key is released
          6. Wait for it to finish. It can take up to 10 minutes.
          • unimatrix93
            • Oct 2021
            • 343
            • Magyarország
            4. Plug in the TV.
            No change.
            I hold down the OK button on the the remote as I plug it in.
            It start blinking slowly and that's it. Like it's not detecting the remote signals. Altough the remote works (tested with camera).
            • 90Ninety
              Crappy Vestel/Sharp LC-40FG3141K Set Backlight going off randomly
              by 90Ninety
              Hello
              Model Code Sharp LC-40FG3141K
              Firstly perhaps I should save myself the agony and throw this set out ? Then again I hate E-waste , or giving a person further headace in the far east or Agbogbloshie . So I digress to my last hope of fixing this pile of shite , with the dash of hope from your combined experiences
              So this set is randomly turning off its backlight ( could be days, hours, minutes or seconds ) , my research suggests this maybe an over current protection , or leaky/faulty LEDS , or a bad LED driver circuit . So I opened it up , stabbed my Multi...
              07-06-2022, 07:09 AM
            • France_53
              Vestel tv, how to flip the image?
              by France_53
              Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
              05-12-2024, 05:22 AM
            • massimomax
              Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
              by massimomax
              Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
              spero che qualcuno può averlo per riprogrammare eprom. grazie
              Post in English !!!
              I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
              02-28-2025, 07:27 AM
            • Adenitz
              Troubleshooting Vestel TV, has standby, but cannot turn ON
              by Adenitz
              I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
              Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
              Both boards are shown in the attached photos.
              What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
              12-27-2023, 03:43 AM
            • Bazilwrc164
              Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
              by Bazilwrc164
              I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
              The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
              I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
              If anyone can provide:
              • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
              • Or a compatible EEPROM dump
              Yesterday, 12:15 PM
