LG 42" Plasma (will enter Model number later)
+ More Options
Posts
  • MadElectroScientist
    • Jun 2010
    Hello, I have a LG 42" Plasma my neighbor gave me because it failed on him and was going to be cost prohibitive to have it professionally repaired...
    I was hoping for some assistance using this forum but wanted to get an idea id anyone was interested in assisting before I dug up all the information about the TV heh...
    Long and the short of where I was and where I am now with the TV is, I got it, powered it up, lights were on but nobody was home (no display), opened it up, found a blown fuse on the Y-SUS board, replaced it, almost shit my pants when it blew again and I saw the miniature fireball appear near the fuse, decided that was stupid, and then continued to look into the issue online...
    Ended up taking the board out and taking off the "Hybrid IC" I believe it is called, and replacing with a $45 Sanyo one off of eBay.
    Removal of the old IC was successful and new IC went on well, old IC actually had a FET or something which exploded out of the bottom of the chip, so that was "comforting" seeing that after I had spent so much time trying to get the old chip out.
    I also added some higher performance thermal compound as the old stuff had dried to dust.
    The unit powered up fine after that, I got a bouncing No Signal box on the screen. All seemed well until I looked at the image a little closer and noticed the characteristic red sparkles on the screen. I have shelved it since then because my understanding is I need to tweak potentiometers and I'm a little apprehensive of getting in there with the unit on and playing with the high voltages (I'm also scared of that fuse!!).
    I was doing a little research on resolving the sparkles and stumbled onto this forum and saw there were some very knowledgeable individuals available on this forum and was hoping for some assistance...
    To this date the set has not been powered for more than 15 seconds or something because I read about "buffers" potentially taking out the Y-SUS board and how the Y-SUS board and Z-SUS boards are supposed to be replaced in pairs, also the hybrid IC is used on both boards so should I just go ahead and replace the one on the Z-SUS board or us it until that one blows, or is that going to take out the new hybrid IC on the Y-SYS I just replaced, also I was supposed to check a Rs voltage I think and make sure it is 205V or something.... So with all these unknowns and the apparant risk of blowing the Hybrid IC I just put in it has been sitting until I feel adventurous enough to get inside it again...
    So if there is interest or this sounds like an easy fix, I'll provide as much info as I can once I get home!
    Thanks!
  • el3ctroded
    • Nov 2008
    • 198
    Re: LG 42" Plasma (will enter Model number later)
    The thing about replacing both Y and Z boards, AFAIK is just the Zsus board is likely near failure since the Ysus board went. Likely due to the thermal compound issue you found on the Ysus. Planned failure? Maybe.
    Testing the voltages is easy to do, once the screen is on just do it. Just make sure your meter leads don't slip. What I did was power up the screen, test voltages, power down, adjust pots, power up screen again until it was right.
    The red sparkles I found were greatly reduced by adding cooling to the Ysus board and adjusting the Vs voltage.
    I've read that the heatsink on the hybrid ics are too small so adding a fan will make it last longer. I just used an 80mm PC case fan and attached it to a 12V wall wart style supply.
    The buffers are likely fine since you got display. If they were bad, you could have taken out the Ysus board again.
    • PlainBill
      • Feb 2009
      • 7034
      I believe the usual recommendation is to replace the Y-sus and and Y buffers at the same time. At a minimum you should examine the chips on the buffer carefully for any sign of damage.
      Go on Scribd and search for the LG Plasma Quick Reference Alignment Handbook and follow the directions for setting up your particular panel. Use an insulated screwdriver, and keep one hand in your pocket. It is not a bad idea to have an assistant standing by to dial 911 just in case something goes wrong.
      As an aside, the model number of the TV should be on the back panel. That helps us help you.
      PlainBill
        • Jun 2010
        The P/N was buried as the TV was buried behind all of the rest of my to-do projects, but now that I uncovered it it is:
        Model Number 42PC3DC-UD.A
        Manufactured June 2006
        Chassis PA-51D
        I appreciate the hand behind the back someone nearby with 911 on speed dial warning, but if I felt that inept with electronics I wouldn't be on this forum
        Besides, that was the warning for back in the day when the residual charge on a CRT could seriously F* you up if you were holding on to chassis ground and completed the path to the CRT anode right?
        I know Plasmas operate by means of glowing balls of gas, (which generally requires high voltages to ionize gasses, bring to a higher energy level, when they lose the energy they crap photon bla bla bla)-- but are there residual high voltages in Plasma Displays? I really don't know that answer, maybe on the power boards (generally accessible only by removing the board and carelessly handling), but not the actual panel display right?
        And I appreciate the suggestion to power it up for brief moments and adjusting incrementally, was reading in some places you gotta make the adjustment after it has been running for 30 min but I'm sure I can improve it from where it's at right now by running the adjustments with it cold, then when convinced Vs is stable, then run it through a burn-in...
        I have never used Scribd before but I'll take a look for that handbook, sounds promising.
        Oh and yes I was considering active cooling for both IC heatsinks, I got some pretty nifty small, quiet 3.3v fans with a side discharge I was thinking of using, they may not move a ton of air, but I think some is better than none as in the present case... Just gotta find a voltage rail which energizes with the panel, can be regulated down and can handle ~50mA additional loading heh...
          • Jun 2010
          Oh and something that has been nagging at me since I heard a friend mention it...
          Someone told me "Oh yeah Plasmas are nice but I couldn't ever get one because they have that one huge fault where they cannot ever lay down horizontal on a surface, because if they do the screen is shot, you throw it out-- that's why they are always shipped standing up in the boxes".
          I find that hard to believe for many different reasons, but I was wondering if anyone here knew where or how that kind of information about Plasmas would come from?
          • PlainBill
            • Feb 2009
            • 7034
            Urban legends abound. That one probably came from a TV salesman who was getting a bonus for every LCD set he sold.
            You do want to be very careful when laying them face down. As a matter of fact, if that TV has the original stand, take a look at the diagram on the bottom of the stand.
            The 'one hand in the pocket' rule is more valid for plasma sets than it ever was for CRT sets. The second anode voltage on a CRT could give you a good jolt, but the current was well under 1 mA. By choosing the appropriate points on a plasma set you can get over 400 volts at .1 amp, enough to stop your heart.
            Not to mention the guy here who was trying to tweak something with a metal screwdriver without taking the back off the set. He managed to short something out. I'm not sure if he ever got it working again.
            PlainBill
            • Lintesir
              Panasonic P42S30 Plasma - Pink sparkles
              by Lintesir
              My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
              There is about a 5cm high region at the top without any sparkles,...
              07-26-2024, 03:16 AM
            • BMCappelletti
              Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
              by BMCappelletti
              Hi everyone.
              Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
              Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
              Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
              02-18-2025, 12:22 PM
            • Nirrain
              Panasonic TX-P42S20E Plasma tv. First purple sparkles, now completely black
              by Nirrain
              I have a Panasonic TX-P42S20E plasma TV that lately has been showing flashing pink pixels when the picture is bright (similar to picture 5 in this post), primarily on the top half but to a lesser degree in the buttom half.
              I've tried to change VSUS to high but it made the issue even worse so changed it back.
              However, this is all a backstory as yesterday after being on for about 5 minutes the screen turned black. I've tried to hard reset (hold power on tv for 30 sec).
              When turned on the green LED flashes 6 times and then stays on continously....
              07-09-2021, 02:38 AM
            • alfredposadas09
              cant enter recovery mode lenovo c13 yoga chromebook
              by alfredposadas09
              cant enter recovery mode lenovo c13 yoga chromebook try esc+refresh+power at first scenario i was able to enter recovery mode but it was failing to reinstall os .. i try to change ssd and when i try this i cant enter recovery mode now...
              11-09-2024, 10:09 AM
            • DerD
              Panasonic Plasma TX-P50Gt30E with sparkles, brightness problem
              by DerD
              I have build up again a defective SC-board TNPA5335 with all! IGBTs and several drivers and other components, after incomplete 6 blink repair and further issues. Finally I got the board almost to work again, running now at least for some minutes without shorting down.
              Anyway, something is still wrong, I guess but not 100% sure that it is on the SC-board.
              Latest step before now was sparkling all over the screen, then Q16820 was replaced and situation now is this. Also to say that Q661, IC921 and other parts for Vad have been replaced too, not only Q401-3...
              05-04-2021, 10:39 AM
