55G310U Toshiba Dead
  • Rmasters3
    • Mar 2010
    • 126
    Can't get anything out of it. Power supply outputs all ) as well. The obvious answer is Power Supply Board unless it needs to be switched on by the Main Board. Suggestions?
    Thanksl
  • neilc6
    • Nov 2015
    • 1550
    Re: 55G310U Toshiba Dead
    Power supply typically supplies standby voltage to the main board. When the TV is turned on, processor will send a power supply on to fully turn on ps and backlight on signal. If you have no standby voltage, power supply is suspect. Should be a main AC fuse you can check but fuses will blow due to shorted components.
    • Rmasters3
      • Mar 2010
      • 126
      PS fuse checked OK, and with no standby voltage, I was assuming a PS problem. Thanks for the confirmation.
      • dskall
        • Oct 2016
        • 2905
        • usa
        What is your voltage across main capacitor?
          03-31-2024, 02:12 PM
        • Asraf Atb
          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
          by Asraf Atb
          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
          01-27-2025, 05:02 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          09-06-2024, 05:59 AM
