Toshiba 58UL2B63DB Suspected Bad Panel
  • Ukdigger
    • May 2020
    • 121
    • England
    I'm guessing that the panel is faulty, but I've never seen one do this before. Can anyone confirm this before I sell it for spare parts.
    • 12330
    • U.S.
    Re: Toshiba 58UL2B63DB Suspected Bad Panel
    very likely, can you give the bezel NOT the screen a squeeze, see if the display changes any.
    • Diah
      • Feb 2013
      • 6573
      i tipp on Firmware issue panel MFC ... re flash an update or downgrade.
      yours MB are 17MB230 , search this forum i linked firmware for full v0.38.30
      • dskall
        • Oct 2016
        • 2905
        • usa
        I would be checking for proper voltages at t-con first.
          • 12330
          • U.S.
          my first thought was bad tab bond contact, possibly "fixed" with shims.
          • Ukdigger
            • May 2020
            • 121
            • England
            My pictures show what happens in sequence when turning on from cold. In the final one the picture freezes and the screen goes about 90% black, the sound carries on working normally, this all happens within a minute or so.
            Squeezing the bezel at any point makes no difference.
            TCON BOARD is CCPD-TC575-009 V1.0 STCON676G
            VCC = 3.2v
            VCOM L = 6.9v
            VCOM R = 4v
            AVDD = 0v
            VGHIN = 0v
            VGL = 1v
            • Ukdigger
              • May 2020
              • 121
              • England
              With the left ribbon disconnected the right half of the screen works perfectly
              With the right ribbon disconnected the left half of the screen has the problem
                • 12330
                • U.S.
                try the tape cut-off method.
                  • 12330
                  • U.S.
                  AVDD = 0v: should be 13-20
                  VGHIN = 0v if this is vgh then probably 20-30
                  VGL = 1v: should be -5 to -12
                  • Ukdigger
                    • May 2020
                    • 121
                    • England
                    AVDD = 15.3v
                    VGHIN = 23.9v
                    VGL = 5.9v
                    • Ukdigger
                      • May 2020
                      • 121
                      • England
                      AVDD = 15.2v
                      VGHIN = 23.6v
                      VGL = 5.9v
                      Has a whited out picture but doesn't fade to black
                      • Ukdigger
                        • May 2020
                        • 121
                        • England
                        Both ribbons connected and voltages have come back. full picture with no fade to black but random faint vertical striping.
                        Shouldn't VCOM left and right be the same?
                          • 12330
                          • U.S.
                          seems like it, I would test all the little caps on the tcon, with panel driver board cables unplugged, if you don't find any short plug cables back in and test again, also test the caps on the panel driver board, with tcon to panel cables unplugged, test diode/continuity mode, one probe on ground, chassis ground is ok, other probe on each side of cap, one side should beep or read close to 000, other side should not beep or have a reading. Can also test for very low ohms.
                          • Ukdigger
                            • May 2020
                            • 121
                            • England
                            I can't find any shorted caps on the T-con board when plugged or unplugged form panel driver board. The caps on the right side panel driver board all test good when unplugged from the T-con board. The caps on the left side panel driver board can't be tested as there is no ground when unplugged from the T-con board but test ok when plugged into the T-con board.
                              • 12330
                              • U.S.
                              vertical stripes or partial vertical stripes can be tcon issue. maybe cleaning the ribbon cables going to panel might help, some use pencil eraser some use q-tip and isopropyl alcohol, not to vigorous they can be delicate, be sure and let it dry a while. Check the side going to the mainboard too.
                              • Ukdigger
                                • May 2020
                                • 121
                                • England
                                I tried the tape method using a paper strip just wide enough to cover 8 contacts. The TV works now with no problems. I watched these two videos to help.
                                Thanks for everyone who helped.
                                https://www.youtube.com/watch?v=pfrRhw7-ZII
                                https://www.youtube.com/watch?v=IQbnbqF_g2s
                                  • 12330
                                  • U.S.
                                  ala post #8, glad to hear it.
                                  • Grandalf
                                    • Sep 2022
                                    Looks like I have a similar problem. How did you figure out which are the clock lines, they are not marked. Have tried second one in and the next 7 from both ends of the connector. No difference at all. Only spare boards available in the uk are from china. Any advice really appreciated
                                    • Grandalf
                                      • Sep 2022
                                      Additional to last post. My Tcon is CCPD-TC575-009-V1.0. This is very difficult to find. Anyone know if any other boards will fit. There seems to be a few different ones all shown as suitable for this model, but not sure if any of these versions will work, mine is 2009 I think
                                      • dskall
                                        • Oct 2016
                                        • 2905
                                        • usa
                                        What voltages are you missing?
                                        • lberkani
                                          Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
                                          by lberkani
                                          I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
                                          The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
                                          The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
                                          I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
                                          - Toshiba 65UL2163DG
                                          - Vestel 17MB180E mainboard
                                          - Panel VES650QNTX-N2-N42
                                          - Version V1.28.100.0 if available
                                          If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
                                          11-11-2025, 12:37 PM
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          Toshiba Satellite L50D-B-11V Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite L50D-B-11V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50D-B-11V boardview and L50D-B-11V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          Toshiba Tecra C50-EC Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Tecra C50-EC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C50-EC boardview and C50-EC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Tecra...
                                          09-06-2024, 09:01 AM
