Samsung UN75RU7100FXZA MOSFET replacement?
  • kevinm34232
    • May 2012
    • 1884
    I was hoping someone can help me find an equivalent replacement for this part:
    Magnachip 60R580QS on the BN44-00992A power board.
    I can only find this exact part in China.. I don't know enough to match up the parameters.. Thanks!
    https://cdn.badcaps-static.com/pdfs/...23fd07e2c3.pdf
  • alfatv
    • Sep 2020
    • 353
    Re: Samsung UN75RU7100FXZA MOSFET replacement?
    As you have original datasheet, you can search for replacement by key parameters.
    Digikey has a good engine.
    Or search the sites of MOSFET manufacturers: STmicro, IRF, Infineon, Onsemi
    • neilc6
      • Nov 2015
      • 1550
      Key parameters are package, N-CH or P-CH, max voltage and max current so you are searching for a 650V 8A N-CH MOSFET in a TO220 insulated package. STF12N65M2 in stock at Digikey looks like a good substitute. Rds is close enough 580 vs 500 milliohms. You can also go higher voltage or current as well if exact match isn't in stock.
      • kevinm34232
        • May 2012
        • 1884
        Thank you so much I'll give those a try! I am not educated enough to be making a substitute on my own!
        • yokoono
          • Apr 2010
          • 475
          The problem is not the replacement. The problem is finding out the answer to the question: WHY DID IT BURN? Otherwise there is the possibility of burning the new one.
            09-07-2024, 05:50 AM
          • DoOm86
            Dual mosfet replacement help
            by DoOm86
            Hello.
            I have a notebook with a shorted mosfet, it's a E6930 GA8125.
            It seems to be a 30V dual asymmetric N-channel AlphaMos.
            Luckily the notebook is working, so I just need to find a good replacement for this mosfet.
            And here is where I need help!
            It's the first time I have to replace this kind of mosfet, I checked on mouse and I found this: (mouser No) = 512-FDPC5030SG.
            I need your help to be sure is a good replacement or there is another with better compatibility, since I can't find the same exact (just from China).
            Thanks!...
            10-31-2023, 12:03 PM
          • jm942
            Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
            by jm942
            My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
            I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
            I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
            I did voltage injection on the cpu with 0.7V and i have a current...
            07-11-2024, 05:11 AM
            09-06-2024, 11:40 PM
