Hello, i need firmware for Vestel 17MB82S, panel VES315WNDA-2D-N11.
Vestel 17MB82S Firmware
Re: Vestel 17MB82S Firmware
Try recovery firmwareAttached Filesif you find these attachements useful please consider making a small donation to the site
by Bazilwrc164Hi all,
I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
If anyone can provide:- A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
- Or a compatible EEPROM dump
07-23-2025, 12:15 PM -
by lberkaniHi everyone,
I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
- Toshiba 65UL2163DG
- Vestel 17MB180E mainboard
- Panel VES650QNTX-N2-N42
- Version V1.28.100.0 if available
If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt... -
by anluHello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model... -
by Davy no CapsHi all,
First time trying to fix a TV for a friend, it's a Bush DLED32165HD.
Power Board - 17IPS11
Mainboard - 17MBS82S
Panel - VES315WNDB-02
Red blinking standby light is on steady, press power button on remote and light flashes 7 times then stays steady, press power on remote again light flashes 10 times and then goes off.
Checked all the voltages on the power board inc backlight circuit, they all read ok and are stable. Backlights tested with backlight tester and all work fine (2 strips x11LED on each).
No picture, backlight or sound just blinking... -
by jorpecHi, all
I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
Thanks10-17-2025, 03:51 AM - Loading...
