Panasonic Oled TX-65FZ800E, no picture, red led blinking every 4 sec
    replied
    Re: Panasonic Oled TX-65FZ800E, no picture, red led blinking every 4 sec
    Thanks Diah.
  • Diah
    replied
    So are improved sockets available. The bypass in post #42 looks interesting, can someone explain the procedure.
    he took thick wire and connect the +24V from boards to boards to reduce the load on the socket
    replied
  • Diah
    replied
    Originally posted by thetech_IV
    Exact same problem here, and same solution
    cheap socket material... good job
  • thetech_IV
    replied
    The connector becomes very hot, more than 60 celcius, I had to pass a wire to remove the heat stress on the connector
  • thetech_IV
    replied
  • Diah
    replied
    SOLVED: Panasonic Oled TX-65FZ800E
    Originally posted by Tof
    So you were right to start by make me change all that burned stuff and now I wonder:
    1- the failure is over and due to too small wires so it will happen again in 3 years.
    2- there is still a component which want to die but slowly.
    What do you think ?
    thank you for yours nice PM.. and thanks for following up..
    the common failure even professional repair persons fail with... when they ignore any socket warm up or cable too or at least color change. any of those material if there shape / color change mean the Resistances has being changed or leak accuse. and this was yours case.
    human Temp 37.6° more or less for good health comparing to ... cable drives OLED cells after 10 minuets you recorded just 37° degree. this is a record better than Chinese design 1000000%
  • Tof
    replied
    I would like to add SOLVE a the tread title but do not find how to do it.
    Some help welcome.
  • Tof
    replied
    I made a new test today, let the tv on few hours and the temperature stay stable.
    So I consider the issue solve and want to thanks the strong support of Diah and lotas on this very helpfull and fruitfull forum.
  • Tof
    replied
    I solder a new connector on the inverter board, the new one is a bit too big but after removing some pins to let only the 15 required, it fit well.
    I remove the connector on the T-CON board.
    I get a 24 wires cable from an old LG TV I had, exactly the same wires 24AWG, 105C, 300V.
    I solder the wires on the T-CON board.
    When checking the old cable wires, I discover that three 24V wires where cut. That means, 5 wires over 8 left for the global 24V power.
    I made a test with a video on HDMI1 and all is working well. I checked the temperature of wires and after 10 minutes, they are warm (about 30 degres) and the main T-CON component about 50degre without the metalic plate.
    What do you think ?
  • Tof
    replied
    lotas you are faster than me, I was looking for the upload link and just find it.... but too late.
  • Diah
    replied
    Originally posted by lotas
    sm
    thanks lotas
  • lotas
    replied
    Originally posted by diah
    can you upload the service manual..
    sm
  • Diah
    replied
    just write the link where you find it. other wise we need the chart lable of the powerboards socket which it go to MB
  • Tof
    replied
    The service manual is a 26MB pdf file and 19MB is the maximum allowed.
    Is there another way to upload it otherwise I split it in 2.
  • Diah
    replied
  • Tof
    replied
    OK I will solder wires directly from EVDD inverter board to T-CON board tomorrow to get good connections. I will go back to sockets later.
  • Diah
    replied
    the 12V are VIN. so next time please called it so. the t_CON had EVSS to montore EVDD 24.V and VIN 12V via VIN - & EVDD - so now you need to jumper direct from EVDD inverter boards EVDD + and EVDD - to the T-CON EVDD socket. notice use neu cable strong enough.. dont use any of the burned socket before.
  • Tof
    replied
    I removed the burned connector and plug the board again.
    I plug video and audio on HDMI1, switch on the TV but no sound.
    The 12V(SVDD) is switch off after 1 sec, even if I push the standby button.
  • Diah
    replied
    I will come back to you tomorrow for a new test result without the socket.
    Diah, lotas, thanks to support me so much.
    not at all from my side ... but dont do any thinks more or less as i asked you before for test pls.
  • riparo
    Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
    by riparo
    Hi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
    I attach a link to download the service manual, thank you for anyone who can help me
    https://tel-spb.ru/download/?brand=P...0E_LA73.rar​
    01-11-2024, 12:35 PM
  • kca
    by kca
    Hello all ~
    08-31-2025, 06:38 AM
    ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
    This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
    09-07-2024, 04:30 AM
  • JSBJSB
    Panasonic OLED TX-65GZ950E no image
    by JSBJSB
    so I have this problem with this OLED that had a LED blinking issue at first.
    It was blinking twice so it means according to similar service manuals (I cannot find the proper one) EVDD 24V SOS, Panel or TCON Fault.
    Also, the connector from PSU to TCON which supplies 24V was burned (changed it) and saw threads about this topic but didn't relate completely to mine.
    First thing was to tape the signal ERRORDETECTION so it would try to initialize. And it didn't so I unplugged the panel from TCON.
    Then it started up and went to green light...
    05-14-2025, 02:39 PM
    Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
    This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-07-2024, 07:12 AM
