Re: Panasonic Oled TX-65FZ800E, no picture, red led blinking every 4 sec
Thanks Diah for the help.
I could disconnect the full black connector on the T-CON board, no signal will miss for the test ?
You first of all need to eliminate these contacts on the connector, when a large T-CON current is consumed with a bad contact, the T-CON power connection is lost and an error is triggered, you need to cut these burnt wires, strip and solder them on the other side of the power supply.Leave a comment:
disconect the EVDD 24V, from PCB side... feed the TV with HDMI signal and turn on you will hear the audio and screen should remain black. if this happend and the set didnt turn off for more than 30 minute give here feed back.Leave a comment:
I did not repair the connector for now, I checked it and it was OK even if the plastic is in bad shape. I will do it after fixing the T-CON board.
About the overheating, I was surprised to but nothing obvious between a test with only the OSD and the full picture. However I am not very confident with thermal camera so I will do some new tests.
What about the Q6004 mosfet, is the mosfet here to switch on/off the 12V ?
I am interesting by any block diagram or schematics if that exists.Leave a comment:
You repaired and checked your bad connector? Surprised you can't find anything overheating.Leave a comment:
Hello everyone, here is the issue I am facing with my Panasonic Oled TX-65FZ800e.
When the TV has not be used for some hours, I power up the TV with a video input and the image is displayed perfectly for 30seconds and then the TV switch off with the red light blinking every 4 seconds for ever.
The service manual explanation: EVDD_SOS (EVDD 24V error) with check point (oled panel, P board, A board, T-CON)
I opened it and found a burned connector on PB-board on the 24V pins.
The 24V wires have change a bit of color due to the overheat and the corresponding connector on T-CON board has nearly no damage.
On T-CON board, I removed the metal plate and detected a bump surely due to overheat on L6006 wich is located on the 12V rail.
I checked all decoupling capacitors looking for a short circuit but found none.
A short circuit exist on the mosfet source Q6004 (SVDD_CS ?), seems strange to me.
I am waiting for a new part but I do not have the T-CON schematics to check the mosfet wiring.
My first feeling is:
- the panel is OK because each time the video input is displayed, the picture is perfect without artifact.
- an overload seems to exist on the 24V line
- an overload seems to exist on the 12V line
I made some other tests to find this or these overload.
I power up the TV without any video source and then the OSD display a small blue box with "HDMI1".
In the case the 24v (EVDD) and 12V(SVDD) are ok, stable, no overload, no overheat on 24V wires.
Then I plug a video input on HDMI1, the video is displayed perfectly, 24v(EVDD) and 12V(SVDD) are OK but the 24V wires between PB-board and T-CON board becomes more and more hot and the TV switch off (no more 24V either 12V).
If I turn on the TV again, the TV immediately switch off, no 24V either 12V.
I use a freeze spray to check if it is due to a componant temperature but no change, the TV switch off immadiately.
To test again with an image, I have to wait for hours.
I try to detect some overheat with a thermal camera but I found nothing obvious for now.
I still think the T-CON board is guilty and I would like to found the origin of the issue. But now I need some expertise to help me go further and confirm or not my feelings.
I wonder:
1- am I right to think the panel is OK.
2- which component can cause an overload on 24V and 12V.
3- on the 12V line, why the mosfet source Q6004 (SVDD_CS ?) is connected to ground.
Thank you all in advance for any help.Tags: None
by riparoHi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
I attach a link to download the service manual, thank you for anyone who can help me
https://tel-spb.ru/download/?brand=P...0E_LA73.rar​ -
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-07-2024, 04:30 AM
by JSBJSBHello everyone,
so I have this problem with this OLED that had a LED blinking issue at first.
It was blinking twice so it means according to similar service manuals (I cannot find the proper one) EVDD 24V SOS, Panel or TCON Fault.
Also, the connector from PSU to TCON which supplies 24V was burned (changed it) and saw threads about this topic but didn't relate completely to mine.
First thing was to tape the signal ERRORDETECTION so it would try to initialize. And it didn't so I unplugged the panel from TCON.
Then it started up and went to green light...3 Photos -
This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-07-2024, 07:12 AM
- Loading...
