Grundig 55 GUB 8860 - bad T-Con or bad panel?
  • Diah
    replied
    Re: Grundig 55 GUB 8860 - bad T-Con or bad panel?
    Originally posted by Ierwin
    I thought it would be smarter to heat up the main chip with a heatgun on low blow setting, while I monitored the chips temperature with an infrared thermometer. Slowly heated it up until the surface reached 250 very briefly, then went down to 190 then let it cool.
    That killed it.
    what ...??we didn't mentioned at all to use hot air gun.. however if some one read this thread in case using normal hot air gun we should cover the chips and all components around with type to avoid one of them move or flying out. and this what happen now.
  • Ierwin
    replied
    Its time to give up unless I find a really cheap mainboard I think.
    Thank you for the help, I have now taken it to the point where the mainboard is definetly toast.
    That killed it.
    Now when I plug the set in, the PSU makes a humming noise and the blue led is no longer blinking
  • Diah
    replied
    200°not enough..in the factory when they apply the soldering pasta first and then the components , it move to the oven which first step 200 then to 310 then back to 150 to the cooling station. t´he worry you have about sockets you can apply kitchen aluminum paper to shape it like cups to cover them. put don't let the paper touch them. this is the packing which i use. beside other method to use Korean in room infrared grill if i want to go only on specification area / chips
  • Ierwin
    replied
    I went up until 200°C with the oven and left the board in for 10 minutes.
    No change at all and I fear if I go higher the plastic ob the connectors could melt.
  • Ierwin
    replied
    Yes,if it is L it's okay
  • Diah
    replied
    it is L not C so it read continues ?
  • Ierwin
    replied
    Do you mean this tiny C? With all cables disconnected I'm reading 0V.
    Might be short but didn't check for other parts in parallel yet
  • Diah
    replied
    Oh if you or anyone else has a chance to get their hands on the correct panel.bin I would still be very interested. As far as I understand I could use a replacement Mainboard from a TV with a different panel then so it would be way easier to find a used part
    can you measure the reading of the small parts connected to pin 44 ? lvds most disconnected during measurements
  • Ierwin
    replied
  • Ierwin
    replied
    I don't remember what Temperature I used back then, it's been 15 years.
    Some sites suggested starting at 100°c and working up from there so that's what I'll do
    As far as I remember you can't really reach a temperature where the solder completely melts without proper tools, only enough for it to get soft and possibly regain connection.
    Will report my results
  • Diah
    replied
    the way you did GPU use the same Temp ca 250 !! and time
  • Ierwin
    replied
    What temperature do you suggest?
    I once got a GPU back to life with this technique so I know it might be worth a try
  • Diah
    replied
    So a loose BGA maybe? That's probably not repairable. But it would be possible that the connection was bad/failing and when I applied cooling spray the temperature stress on the soldering joints made it worse.
    So nothing else to do but get a replacement Mainboard?
    well. before i go to buy replacement MB the stress you mentioned could be, in this case i encourage you to packing the MB. in the oven with out air flew after you remove from the down side i think there are rubber legs
  • Ierwin
    replied
  • Diah
    replied
    if both pins 44 & 51 have V. then my early post #8 are in place... you have drooped signal feed with main IC on main boards.
  • Ierwin
    replied
    I found that section of the SM earlier and checked. I'm not at home right now and don't remember the voltages but both were equal.12V I think. Definitely not 0
  • Diah
    replied
    Okay so I measured all the ribbons with a continiuty tester (beeping).
    I slowly draged the probes over the contacts of the connectors on each side.
    I admit I did not take the time to probe each of the tiny contacts perfectly individually so if lines are shorted I wouldn't know. But at least I did not find any broken lines
    Okay. now every things in place and follow the S.M after turn on and you press menu ( BL go brightness) measure voltage on pin 44 & 51 if you have missing V on 44 check the yellow parts.
  • Ierwin
    replied
  • Diah
    replied
    pressing menu the backlight goes brighhter but nothing apears on the screen.
    okay,,, you need to inspect the LVDS cable and the 2 ribbon cable under good loop. the material they used on this TV are the cheapest one with bad quality easy the contact pin after 1-2 time take them out from the socket will brocken
  • Ierwin
    replied
    I have never had a panel.bin on my USB stick, so it should never have overwritten. But because it stopped working after one of these flashing attempts I think the panel setting might have been deleted.
    I found the ssticker on the chasis (fun fact: couldnt find it before because my multimeter was standing on it ).
    But the number is the same as the small sticker on the back: 55C46P
  • mmartell
    General Questions on the Relationship Between Mainboard, TCON and Panel
    by mmartell
    My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
    I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
    And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
    01-06-2024, 01:32 PM
  • Helikvar
    Hisense 58A6KV
    by Helikvar
    No picture ,tv appears to turn on and off using remote as standby led goes from red to nothing when on and red again when off
    . Backlights also light up when tv is powered on.
    Removing panel ribbon cable from left side screen still dark.
    Removing panel ribbon cable from right side the right panel is white and left panel is dark but within a few seconds the left panel has a large green vertical bar and beside it many thin red lines.This whole screen dims down to dark within a few seconds and the right side slowly turns white again.
    . Tcon gets 12 volt
    . Tried taping...
    02-21-2025, 03:52 PM
  • Lee M.
    Amazon Fire TV Omni K24NE5 tcon or panel bad?
    by Lee M.
    TV came on with BL on but blank screen. Disconnected one of the ribbon cables from tcon to panel driver board and now I have half of the screen working normally. Any way to tell if the problem is with the tcon or the panel driver board or the panel itself? Should I just replace the tcon and see what happens?
    05-12-2023, 05:47 PM
  • ashyt16
    Toshiba TV bad panel half screen dark - pull tabs or not?
    by ashyt16
    Hi fellas, I have a Toshiba 50u6863db (vestel crap) here belonging to a family member.
    The TV was given me to repair (possibly) as it had developed a blank screen, just back lights and sound.
    Upon further investigation it turned out one of her cats had sprayed on the screen as I could see it on the edge of the panel and tabs and it stank. Looks like it probably shorted the circuitry. I cleaned it up and still the same.
    I initially suspected Tcon board as none of the test points were showing correct voltages. Tried removing one LVDS cable at a time, same result....
    10-26-2020, 05:47 AM
  • stylishconsultant
    un60j620dafxza - Samsung No Display Problem
    by stylishconsultant
    Hi All,
    Need help.
    I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
    So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
    problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
    might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
    09-04-2024, 03:26 AM
