Lg 32LB75
+ More Options
Posts
  • nezocas
    • Oct 2015
    • 27
    • Alcanena
    Lg 32LB75
    Tv not starting correctelly... goes out of standby with green led and back to standby.
    PSU: EAY38639701
    All caps in PSU were ESR and capacitance tested, inclunding the problematic ones on the mainboard C227/543/958/853/959/970.
    PFC is 395Vdc
    If I bypass the ERROR pin in the plug 201 and connect it with a 100homs resistor to the 5v rail, Tv workΒ΄s with sound but no backligth present.
    All voltages on p201 present with the bypass.
    Not sure what to do...???
    Regards
    Nezocas
  • Garion60
    • Jan 2022
    • 6
    Re: Lg 32LB75
    Can you provide more symptom details, please?
    • neilc6
      • Nov 2015
      • 1550
      Re: Lg 32LB75
      If TV has no backlight or flash of backlights, backlights are the first suspect. Especially LG LA, LN, LB or LF series.
      • nezocas
        • Oct 2015
        • 27
        • Alcanena
        Re: Lg 32LB75
        Hello again,
        All 14 CCFL tubes were tested individually with my tester.
        On the Q707 there is only 18v, it should be 24v from what I have read online.
        But I have no schematic from this PSU.
        I have followed this topic, but the fault is not the same, I dont even get a blink from the tubes:
        https://www.badcaps.net/forum/showthread.php?t=37829
        • neilc6
          • Nov 2015
          • 1550
          Re: Lg 32LB75
          Sorry thought TV was LED. Not familiar with European model numbers. Odd LG reusing the numbers. CCFL TVs are pretty old and obsolete and 32 in one can be usually found for free. Maybe someone more experienced with CCFLs can help you. You can check for shorted FETS on the inverter board and also measure the secondary transformer impedances to see if they match.
          • nezocas
            • Oct 2015
            • 27
            • Alcanena
            Re: Lg 32LB75
            Tv was scraped, to many hours to fix old tv.
            Regards
            • Spudgun
              Why doesn't current just bypass faulty capacitors.
              by Spudgun
              Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
              04-01-2025, 10:33 AM
            • Arshad alam4659
              a1466 smc bypass
              by Arshad alam4659
              what is smc bypass and how does it work and how to bypass it i want to know can anyone tell me about it
              11-09-2024, 08:22 AM
            • oxonater
              Apple MacBook Pro A2141 16" IC BYPASS
              by oxonater
              Hi everyone hope all are well
              I need a little expert advice on a issue I have and seeing as this forum is full of clever people I thought ask here as you never know.
              I recently repaired a logic board 820-01700 which belongs to a 16" 2019 Macbook Pro, however I seem to be missing a component near the T2 Rom chip and is U4730.
              The schematics say this chip is (M34128-FCS6_P/T) and it also says there is a bypass for it wondered if anyone come across either the IC or the bypass method.
              I suppose it's worth noting googling the part package brings up various...
              10-23-2024, 11:21 PM
            • Yacine007
              Lenovo yoga c740-5IML MDM bypass
              by Yacine007
              hello everyone hope everything good,
              please can someone help me to bypass this laptop lenovo yoga c740-5iml, i canΒ΄t create local account i tried several commands CMD without succes.
              Model : 81TD
              SN : PF2AFN38
              MO : PF9XB0525250
              MTM : 81TD0067MH
              Factory ID : JVHFC1
              MFG : 25/05/20...
              03-21-2025, 08:53 AM
            • harounHD
              Macbook a1989 and a2338 icloud bypass
              by harounHD
              Is there a solution for Macbook a1989 and a2338 icloud bypass , i saw a video on youtube of someone using a bootable usb to unlock it
              02-01-2025, 03:23 AM
