samsung BN44-00599A PWB
  • ajshoe
    ajshoe
    • Dec 2012
    • 477
    • usa
    Re: samsung BN44-00599A PWB
    on this tv - only one row of 7 pins goes into that black connector (you show 2 rows but the connector only has 1 row of 7 pins - 7 wires). I may have checked voltages on wrong pins - i'll check them again tomorrow.
    there is nothing else that plugs into main board except speaker connector, power board connector, and ribbon connectors.
    • R_J
      • 9535
      Is this your board? if it is there are two rows of pins, the row exposed on the top of the main board do not connect to the joystick board
      The connector has 18 pins, two rows of 9 pins. Unplug the connector and look at the plug.
      I still count 8 wires on the plug between the joystick board and the main board.
      • lotas
        • Jan 2016
        • 4589
        • Russia
        Here is the pinout of the joystick.
        • ajshoe
          ajshoe
          • Dec 2012
          • 477
          • usa
          that is my main bd - obviously it has 8 wires. I was looking at post #16 (lotas) pinout. I'll measure voltages shortly and report back.
          • ajshoe
            ajshoe
            • Dec 2012
            • 477
            • usa
            with joy button 8 pin connector disconnected. orig main bd in - all pins had 12-15 Mvolts except ground pin. with new EBAY main bd - all pins had 205 Mvolts except ground. NO 3.3 VOLTS on any main bd joy button connector pins. tells me I have 2 bad main boards.
            standby was 3.3V and 5V was 5.1 volts. on main board PWB connector
            • ajshoe
              ajshoe
              • Dec 2012
              • 477
              • usa
              #26
              anybody know how 3.3 volts gets to joy button from main bd from power supply ? anything I should be looking at or Main bd not worth the time ?
              • R_J
                • 9535
                There should be buck regulators on the board, they would take the A5v and drop it to 3.3v They usually are an 8 pin ic with a coil near it, there look like a couple circuits like that near the hdmi1 port.
                Look up or post the numbers on the ic to see if they are regulator ic's
                There are also 3 pin ic regulators with numbers like LD1117
                You can also try tracing back from the A3.3V test point using your meter in resistance mode.
                • ajshoe
                  ajshoe
                  • Dec 2012
                  • 477
                  • usa
                  #28
                  thanks - I will take a look
                  • ajshoe
                    ajshoe
                    • Dec 2012
                    • 477
                    • usa
                    #29
                    most likely another chip on that 3.3V line thats shorted out. I read something about this main board having a bad chip - samsung has a tech bulletin out on this board. should have been a recall. terrible how manufacturers are putting everything on 1 board and NO SCHEMATICs available
                    • ajshoe
                      ajshoe
                      • Dec 2012
                      • 477
                      • usa
                      #30
                      found this training manual - too bad they didn't go over joy stick button testing or 3.3V checking on connector CN1202
                      also technical service bulletin about main board
                      • ajshoe
                        ajshoe
                        • Dec 2012
                        • 477
                        • usa
                        #31
                        joystick button CN1202 Pin 3 (A3.3V) is shorted to ground (joystick is disconnected). USB connector VCC is not attached to LD1117 anywhere. maybe goes thru resistor to USB port. The two LD1117 i found are not shorted. this board is a nightmare without schematic. Tab of LD1117 is VCC-out and can't locate where it goes. Also LD1117 VCC-in doesn't go directly to standby (PWB)
                        • ajshoe
                          ajshoe
                          • Dec 2012
                          • 477
                          • usa
                          #32
                          Main bd pics
                          • ajshoe
                            ajshoe
                            • Dec 2012
                            • 477
                            • usa
                            #33
                            traced CN201 (main bd conn to PWB) standby voltage to Samsung prop chip sps-HI16.
                            all buck regulators (found 3) have 0 volts at input with main power on.
                            I give up - main board is a nightmare to trace. not worth my time.
                            • ajshoe
                              ajshoe
                              • Dec 2012
                              • 477
                              • usa
                              #34
                              quick follow up - bought second main bd and installed it. had 3.3 V at joy stick button connector. put it together and works perfectly. Lesson learned - watch who your buying boards from - lots of sleaze balls out there. Bottom line this main board is not worth working on (my opinion).
                              • tvtimmy
                                • Mar 2015
                                • 1160
                                • usa
                                #35
                                Post #16 nailed it.
                                • deloveyou
                                  • Jan 2022
                                  • brasil
                                  #36
                                  bom dia, tambem preciso do esquema eletrico pn51f4500 ou placa da fonte bn44-00599
                                    09-07-2024, 05:50 AM
                                    09-06-2024, 11:40 PM
                                    09-06-2024, 08:40 PM
                                    09-06-2024, 06:20 PM
