Please, help with Samsung UE32D5000 diagnostic problem
  • Dawor
    • Dec 2021
    • 6
    • Croatia
    Problematic horizontal lines and picture scattering are visible in attached images.
    Please help determine where the malfunction occurred. I checked all the cables and connectors on all the boards inside the TV. There are no visible defective elements on the boards.
    Factory reset also done but no improvement.
    Which board could be wrong?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Please, help with Samsung UE32D5000 diagnostic problem
    Looks like timing control problem. Possible panel problem.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4427
      • Italy - Milan
      Problem with one side gate drivers, seems lagged, needs a picture of entire screen, maybe fault begin from a certain line, tipical, one of the solutions the masking tape method..
      • Dawor
        • Dec 2021
        • 6
        • Croatia
        Thanks for the quick answer.
        I photographed the whole screen and additionally each side separately. I think the resolution is poor to see the details, so I still shot every corner in macro mode.
        I hope that helps.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4427
          • Italy - Milan
          The whole screen is affected, so detach one tcon output cable at a time and see if you have an half good image situation.
          • Dawor
            • Dec 2021
            • 6
            • Croatia
            When the left output connector is disconnected on the t-con it is obtained as in the picture (discon_left_t-con.jpg) and the visible part of the message on the screen is clean lines but every 2nd line is black (message_macro.jpg).
            When the right output connector is disconnected on the t-con, it is obtained as in the picture (discon_right_t-con.jpg) and the screen darkens completely in ten seconds (discon_right_after10s_t-con.jpg). The expected second half of the message is not displayed at all.
            Still wondering where the fault is, on the t-con board or the panel is gone?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4427
              • Italy - Milan
              The fault is on the panel maybe you can fix it nearly well with tape masking method, post photo of tcon with visible serigraphs
              • Dawor
                • Dec 2021
                • 6
                • Croatia
                Panel fault means the TV is a waste.
                So I would definitely try that method of masking, to save what can be saved. T-con image is attached, which pins and on which connector should be masked?
                Thank you very much for your help.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4427
                  • Italy - Milan
                  Everything starting with CK, on the connector of the faulty side that is the one that shows almost black, there are testpoints near right connector but are paralled to the left.. you can also try to block each one at a time that wil preserve more signals but it's longer to do.. you have at minimum 2 faulty lines..
                  • Dawor
                    • Dec 2021
                    • 6
                    • Croatia
                    Thanks a lot for the instructions.
                    Maybe I should first try to measure the voltage differences at the test points of the pins between the left and right connectors to determine which pins to mask?
                    In order to do it well, I need to provide more time, so I will leave it for the weekend.
                    At the end I will definitely announce the final result here. Maybe help someone else.
                    Thanks again for the big help.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4427
                      • Italy - Milan
                      yes its a good idea to measure voltages,but if you have a multimeter with frequency meter or if you buy one like a cheap ZT301 / 302 it's easier, maybe the faulty clock it's shorted to gnd or else.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        This video maybe worth a watch https://www.youtube.com/watch?v=SbGAkRgaZhs
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4427
                          • Italy - Milan
                          i don't know why making tech videos speaking so fast.. it's only to make money or he wants to teach something..?
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            I really hate this too.
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              Try learning how to repair panels and t-cons when they are all in hindi, tagalog etc. India seems the only videos that get into real repairs of this kind.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4427
                                • Italy - Milan
                                this because in India there is real poorness and an electronic device must last longer.. the guy of the previous video seems a real expert and when my pc will be working again i will make start-stop easier with that and some French new videos that goes deep into lcd tech that i almost know but not entirely due to language limits..
                                  09-07-2024, 05:50 AM
                                • howardc64
                                  Samsung UN55JU650DF network/streaming problem
                                  by howardc64
                                  Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                  This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                  07-09-2025, 12:44 PM
                                  09-06-2024, 11:40 PM
                                  09-06-2024, 08:40 PM
