TCL 75R615 has sound, no backlight
  • thetonywarren
    • Feb 2013
    • 149
    Have had this TV since June 2019, worked fine till today. Daughter was watching it and made a noise and went dark. I unplugged, left off then powered back on, no change. You can see the image with flashlight test, but has high pitched noise/whine and no backlight whatsoever......I also tried a factory reset with the reset button on the back. Any ideas where I should start troubleshooting? Im pretty good with soldering iron and multimeter, but I dont have any documentation on this TV so I dont know where to start.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: TCL 75R615 has sound, no backlight
    I would start at power board. Sounds like shorted component causing the led driver to make noise. Need some pictures of boards.
    • thetonywarren
      • Feb 2013
      • 149
      So, I got some help yesterday to take the TV off the wall and got the back off to check out the boards....I did find a capacitor that was blown out,looks to be C312 a ceramic disc capacitor, very small and challenging to read, but was able to with a magnifying glass.....it seems to be a 220pf 1kv, I ordered some new ones from digi-key. A couple of questions, I dont notice with this type of capacitor that there is any polarity that needs to be observed? I have replaced numerous electrolytic caps and they have obvious polarity markings on the circuit board as well as the cap itself. Please see the attached pictures of the part number of the panel as well as some pictures of the internal boards, please offer up any help if you can....Thanks.
      • dskall
        • Oct 2016
        • 2905
        • usa
        No polarity on those. Does it measure as shorted?
        • thetonywarren
          • Feb 2013
          • 149
          I just checked the component via continuity test and it is shorted.
          • lotas
            • Jan 2016
            • 4708
            • Russia
            This is a high-voltage ceramic capacitor, they have no polarity, you can safely install it as you like.
            • dskall
              • Oct 2016
              • 2905
              • usa
              You can probably remove it and see if everything powers up. Just read my disclaimer first.
              • thetonywarren
                • Feb 2013
                • 149
                I think I'll wait till I receive the new component, before I power it back up....
                • R_J
                  • Jun 2012
                  • 9581
                  I would remove the disc cap and check it out of circuit, I would also check the mosfet QW301 & QW302. I usually replace these 1kv caps with a 2kv
                  • thetonywarren
                    • Feb 2013
                    • 149
                    When you say take the disc cap out of circuit, I'm assuming you mean the one that blew up and not another one near it or a different one? I did desolder it took it out of circuit and it tested shorted out ....I'll also check the two MOSFETs like you suggested......crap, I already bought the 1kv version instead of the 2kv like you said.....
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      I'm surprised you had video.
                      • R_J
                        • Jun 2012
                        • 9581
                        The 1k will be fine if that is what you ordered.
                        • R_J
                          • Jun 2012
                          • 9581
                          It seems to be the PFC circuit that has the shorted cap. The main board, t-con etc. likely operated and gave video but the led circuit needed the higher voltage and current to operate.
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            Thanks again for the info. I get on here mostly to learn. Do you know what happened to budm? Looks to be about a year since he posted.
                            • thetonywarren
                              • Feb 2013
                              • 149
                              QW301 & QW302, as far as testing them....can they be tested in circuit, or do they need to be removed to be tested, I just want to make sure I do it the correct way.....im sure I can google a testing procedure, but I want to do it the quickest, most correct way....
                              Please let me know and thanks again for everyones help with this, it is much appreciated.....
                              • lotas
                                • Jan 2016
                                • 4708
                                • Russia
                                You can check without soldering them, their legs should not be short-circuited with each other, this capacitor is parallel to the diodes.
                                • thetonywarren
                                  • Feb 2013
                                  • 149
                                  Ok, I'll test them later on this afternoon and post results on the mosfets....
                                  • thetonywarren
                                    • Feb 2013
                                    • 149
                                    I tested both QW301 & QW302 in circuit and they are testing open across all legs.....I'm assuming per previous post that this means they are most likely good....
                                    • dskall
                                      • Oct 2016
                                      • 2905
                                      • usa
                                      Well they shouldn't test open. Probably not testing them right, but they almost always test shorted if bad.
                                      • thetonywarren
                                        • Feb 2013
                                        • 149
                                        Ok, does anyone have a good source for how I should be testing these particular mosfets? Ive viewed a few videos on youtube, but just looking for suggestions.....
                                        Thanks!
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • triplefour
                                          TCL 75S421 has sound but no backlight not even a flash
                                          by triplefour
                                          TCL 75S421
                                          PSU BOARD: 40-L402H8-PWD1CG
                                          it shows not even a flash of backlight when powering up.
                                          but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                                          testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                                          unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                                          i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                                          with mb connected, PSON...
                                          11-17-2023, 09:54 PM
                                        • apnar
                                          TCL 75R615 - no picture but working backlight & sound
                                          by apnar
                                          Hello all! New to TV repair and trying to bring a TCL 75R615 back from the dead. I've tried to do my basic research/reading but am at a loss so thought I'd see if anyone had some suggestions.
                                          The TV powers up and I can see the backlight on. I can hear sounds by navigating the remote.
                                          I tried disconnecting each side of the LVDS cables one at a time, powering off for a while between, and it didn't change anything. So my first guess was the TCON board so I order a replacement and swap that in. Didn't change anything.
                                          Next I thought I'd try swapping the...
                                          07-22-2022, 12:49 PM
                                        • televizora
                                          HP 8470p - distorted sound and noise when playing audio
                                          by televizora
                                          Hello.
                                          I have an issue with HP 8470p - rather strange one.
                                          I have a noise and sound distortions on both internal speakers and external speakers, when I plug such into the 3.5mm audio jack.
                                          Seems like the noise is present especially when I play audio, where there are parts/sections where the volume of the actual recorded sound is low.
                                          Interestingly, when I play the windows sound test, everything seems to be almost okay. The sound/distortions are similar to when you have interference from some other piece of equipment nearby or when you have an audio receiver with bad amplifier...
                                          12-31-2021, 10:25 AM
