Hisense 65K560DW Power Supply problem
  • boyebaran
    • Sep 2015
    • 249
    • iran
    hi to all
    I have a Hisense 65K560DW TV with problems on the Power Supply Board
    part number: RSAG7.820.4877
    My issue was the standby 12V not stable and changing between 11.2 to 12 v. This was causing the power supply to go into a protection mode . Only symptoms externally was blinking dim standby led.
    Measured across VZ901 but the voltage was also fluctuating there. I discovered the rectified DC output from VD901 and VD902 was not stable with approximately a 40V ripple.i attached pdf
    please advise me
    tnx
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Hisense 65K560DW Power Supply problem
    Check for shorted parts and caps. in standby circuit
    • R_J
      • Jun 2012
      • 9627
      What are the E. B. C. voltages on V901? VZ901 may be bad
        03-31-2024, 02:12 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        07-01-2024, 06:34 AM
      • JimBanville
        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
        by JimBanville
        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
        09-13-2023, 07:21 AM
      • stylishconsultant
        un60j620dafxza - Samsung No Display Problem
        by stylishconsultant
        Hi All,
        Need help.
        I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
        So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
        problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
        might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
        09-04-2024, 03:26 AM
