Samsung ue49mu6120
This topic is closed.
  • Marty-Club
    • Aug 2019
    • 23
    #41
    Re: Samsung ue49mu6120
    https://www.ebay.co.uk/itm/MAIN-BOAR...-127635-2958-0
    I have seen this board samsung ue49mu6220
    Will this be compatible with My ue49mu6120..
    Rgs Martin.
    • Storyteller12
      • Jun 2020
      • 624
      The board may or may not work. It depends on the version also. However you can take the eeprom from the working board and put it on your board and it should work.
      • Storyteller12
        • Jun 2020
        • 624
        I just did this. You better off buying a better programmer like I did and fixing yours. That way you can fix it in the future if it happens again.
        If not your back to buying another main board.
        • Marty-Club
          • Aug 2019
          • 23
          #44
          which programmer did you buy Storyteller?
          • Storyteller12
            • Jun 2020
            • 624
            Rt809F
            • mehrzadjalali
              • Dec 2013
              • iran
              #46
              Originally posted by lotas
              This chassis is famous for its standby firmware rally in SPI Flash W25Q40CL (IC1604).
              If you have a programmer, then copy the contents of W25Q40CL (IC1604) and post it here, I'll fix the dump for you.
              i have chassis JAZZ_L_BUILT-IN BN-41-02528a with same symptom if possible tell way can edit or edit the dump that i attached from chassis W25Q40CL if any information need please inform me
              thanks'
              • lotas
                • Jan 2016
                • 4597
                • Russia
                #47
                thanks'
                XXMUxxxx and XXKUxxxx are different chassis, platforms, what is the malfunction of your samsung, are there all voltages on the motherboard?
                • mehrzadjalali
                  • Dec 2013
                  • iran
                  #48
                  will not turn on, no standby light but when i remove the psu cable from main board i get back lights and when press remote power on, standby led flash once
                  all voltage are ok except HAVDD_8.5V & HVIN_12
                  • lotas
                    • Jan 2016
                    • 4597
                    • Russia
                    #49
                    It is not clear when you disconnect the power supply from the main board, how the standby indicator might blink.
                    • mehrzadjalali
                      • Dec 2013
                      • iran
                      #50
                      standby indicator blink when psu connected not when i remove psu, when i remove the psu cable from main board i get back lights
                      • lotas
                        • Jan 2016
                        • 4597
                        • Russia
                        #51
                        Try these dumps to check
                        • angel-boy
                          • 550
                          #52
                          can you lern me how to fix the dump ? thanks
                          • lotas
                            • Jan 2016
                            • 4597
                            • Russia
                            #53
                            With the help of a hex editor.
                            • ValiIT
                              • Nov 2020
                              • România
                              #54
                              Re: Samsung ue49mu6190
                              Hello, help me please whit this firmware, the tv has no stand-by, power supply and led is ok. Thank you.
                              • ValiIT
                                • Nov 2020
                                • România
                                #55
                                • lotas
                                  • Jan 2016
                                  • 4597
                                  • Russia
                                  #56
                                  Try, do not forget about the status of the register.
                                  • ValiIT
                                    • Nov 2020
                                    • România
                                    #57
                                    Tv work, backlight is ok but no image with this dump.
                                    • AndreaM
                                      • Aug 2022
                                      • 5
                                      • Italy
                                      #58
                                      Hi ,I have the same TV Samsung ue49mu6120 and the same problem...the electronics is OK (after I replaced the main fuse) but the TV is dead.Now i de-soldered the 1604 chip and dumped the firmware and i see a lot of FF.Any chance that any of you beautiful people can help me too? .Thank you.
                                      TV ue49mu6120
                                      MB BN41-02568A
                                      • lotas
                                        • Jan 2016
                                        • 4597
                                        • Russia
                                        #59
                                        TV ue49mu6120
                                        MB BN41-02568A
                                        Try
                                        • AndreaM
                                          • Aug 2022
                                          • 5
                                          • Italy
                                          #60
                                          Try
                                          Sorry for the late replay.First thanks for the super quick replay.Second no luck the TV with the new firmware does not power on.I suspect I missed something on the MB...
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Flex NP950QCG-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Flex NP950QCG-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-X01DE boardview and NP950QCG-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
