Originally posted by alex39t
View Post
Samsung ue49mu6120
Originally posted by alex39t View PostWhen i push button 1 time to 10 turn on it has the logo and after only backlightAttached Files
Hello Lotas and all.
I have read here much and this community is very nice. Much to learn.
But I no longer make any progress and hope of your help.
I have a UE55KU6170UXZG Curved TV. I have changed the Mainboard BN41-02528A (with a UE55KU6179UXZG) and the PowerSupply but problem exists.
With the UE55KU6170UXZG M/B:
The Standby LED goes on and off, stays off for 30 seconds and repeat. No Backlight.
With the UE55KU6179UXZG M/B:
The Standby LED is steady on, no Backlight. If I press ON the Power LED goes off and then on, and stays on.
If I remove the cable between PSU and Mainboard Backlight is on.
I have jumpered the FB_TRDY 1/3 and removed one LVDS Cable, and than the other but no change.
Is there a Software Problem?
I uploaded you the Files from UE55KU6170UXZG and UE55KU6179UXZG, I hope you can look and find something.
Originally posted by fanaticgames View PostI have this UE55MU6125K TV, it doesn't turn on and doesn't show any red LED (the power board works though and powers the panel and backlight correctly), is it a corrupt eeprom problem?
Originally posted by lotas View Post
90% of the standby indicator does not light up in the "MU" series; the problem is in the spi flash 25Q40 firmware.
I don't know how to check and fix it, can you check? That's the dump, thanks
1. First you need to delete all status registers (uncheck all the boxes and click "Write")
2. Erase the chip.
3. Write down the corrected dump and check what was written down.
4. Set the status register (0x88, 0x42), check the boxes and click "Write"
5. Everything is ready, solder the chip in place....
Originally posted by Shwed84 View PostRe: Samsung ue49mu6120
I have the same problem with my
SAMSUNG UE40MU6470UXRU .Can you help me ?
Thank you
MB: BN41-02568B
LCD: CY-KK040HGNV3V
the number on the sticker: BN94-11958K
This is the wrong dump, the dump you need is not 25Q80, but (IC1604) 25Q40!Attached Files
Originally posted by Martin_CZ View Postplease modily firmware. Samsung UE49MU6170. Many thanks. MartinAttached Files
