Samsung UN50KU6300 Leds wont stay on
  • handsworth
    • Oct 2015
    • 175
    I'm doing some basic diagnostics on this tv trying to find out if the main board, PS or leds are causing the problems. There is no T Con. When tv is turned on the Leds come on then go off. 20 sec later, they repeat the process over and over. Ok so I pulled the connector from the main board and replugged. All leds are lit and stay on although some had turned blue. I switched PS and got the same result. Switch MB and the results are same again. Also disco'd lvds from panel, same results, I just ordered a new set of leds cuz I would need them anyway. What is going on here? Any advice.
  • neilc6
    • Nov 2015
    • 1550
    Re: Samsung UN50KU6300 Leds wont stay on
    I have seen bad LEDs flash on Samsungs. Without protection shutdown, one intermittent LED can cause the whole string to flash.
    • handsworth
      • Oct 2015
      • 175
      So I just installed all new leds and the same is happening. Switched power supplies and same results. PS alone keeps them lit. Im thinking MB at this point. Any suggestions?
      • lotas
        • Jan 2016
        • 4918
        • Russia
        The problem may be in the panel itself.
        • Storyteller12
          • Jun 2020
          • 625
          Some of these Samsung models have bad caps on the panel driver board. Check and see if any are shorted. If not try the tape method to see if it keeps the backlights on. If so it’s the panel itself as mentioned.
          • CapLeaker
            Leaking Member
            • 8352
            Everything disconnected, besides the backlights connected to the power supply, the LEDs should turn on and stay on as long the PSU is plugged in and getting power.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4546
              • Italy - Milan
              List or make a photo of the PSB table of the connector to main board signals. Have you installed new leds or led bars? Try to power on with panel or half panel disconnected. Try to locate a fuse on mainboard.
              • MahdiA
                • Oct 2021
                • 4
                • Iran
                To Diagnosis ;
                Unplug main from smps, If backlight remain
                Unplug address from main, If backlight remain
                Test the address one by one.
                To identify the problem.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4546
                  • Italy - Milan
                  already said
                  address
                  what the hell is?
                  • handsworth
                    • Oct 2015
                    • 175
                    Re: SOLVED: Samsung UN50KU6300 Leds wont stay on
                    So I stopped replacing parts for this seemingly easy fix and started investigating posts #3 and 4. This is what I found. Its not an led problem but a screen issue. Seems the tv was power cycling.
                    1. Power cycling, backlight turning on and off or no picture on this model is because of a bad screen, replacing main board does not solve these issues. By the way, if you have other issues just keep in mind to update the firmware on this main board right after you installed it by connecting it directly to internet otherwise main board will go out again in a short period of time (Firmware must be updated on all Samsung KU series after replacing the main board with a new one)
                    2. In another post I found on this site, if everything is connected except the panel tabs, it still will not turn on, but the leds will blink. This is a KU tv issue.
                    Hope this helps someone
                      09-07-2024, 05:50 AM
                      09-06-2024, 11:40 PM
                      09-06-2024, 08:40 PM
                      Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                      This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 06:20 PM
