Philips 43PUH4900/88 will not power up
  • R_J
    • 9535
    Re: Philips 43PUH4900/88 will not power up
    Since you have a scope, do you have any output from the LD5532GS ic? 12v on the vcc pin seems low, it should be closer to 16v to turn on. Also check the dc voltage on pin #1 it should be over 1 volt dc, if 0.8v or less the ic will be off.
    • HellasTechn1
      • Sep 2015
      • 176
      • Greece
      I measured the output and is 0V. Right after taking the measurement my probe's tip sliped and shorted pins 5 and 6. Now i have a main fuse blown and R9308 and 9309 shorted. I am also going to measure the mosfet later and let you know. The LD5532 is probably dead also, if it wasnt dead before. Also is D9304 a zener diode ? It reads like a normal low impedance diode on the DMM (the same before i shorted the ic).
      • HellasTechn1
        • Sep 2015
        • 176
        • Greece
        And yes. The mosfet is also shorted now. So i guess i have to order a new LD5532GS, replace the mosfet and the resistors and it might as well work all right.
        Is D9304 a zener diode indeed ?
        • lotas
          • Jan 2016
          • 4575
          • Russia
          D9304 -SS1060FL is not a zener diode, it is a 60v 1.0A SURFACE MOUNT SCHOTTKY BARRIER DIODE
          • HellasTechn1
            • Sep 2015
            • 176
            • Greece
            Right. Thanks !
            I mixed the schottky symbol with the zener symbol.
            • HellasTechn1
              • Sep 2015
              • 176
              • Greece
              #26
              I am going to place an order on ebay for the parts. It will probably take a month or two before i get them. I am going to post back to let you know what happened.
              Thank you all for your help !!!
                by sam_sam_sam
                03-31-2024, 02:12 PM
                09-06-2024, 05:59 AM
                HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-12-2024, 02:15 PM
              • meraklinetx
                Asus Z97-a power cycle, no boot no cpu voltage
                by meraklinetx
                Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                05-10-2023, 06:08 AM
