Weird Display Behavior -- LG 49UH610V
  • Gjackson
    • Aug 2021
    • 134
    • Malta
    I've got an LG 49UH610V that has some weird display problems. The LCD panel itself doesn't seem to be broken but It keeps alternating between a good image and a bad image around every 2 seconds. (so it seems fine for 2 seconds and then switches bad for 2 seconds and keeps alternating, see video attached)
    At the top of the screen there is a pink horizontal line which isn't visible in the video, this line never goes away it's always there no matter if the screen is currently "good" or "bad".. when I disconnect the left side of the Panel from the T-con, it only shows a solid image of vertical black and white bars however when I disconnect the right side, it shows the same bars but every 2 seconds these bars start to shake and then go back to normal and keep alternating just like the main symptom.. Any ideas on what's happening?
    Something else I should mention, the T-Con main IC gets quite hot (not sure if It's normal.)
    Link to Video : https://files.fm/f/p7ggchcn9
    Thanks in advance
  • lordmmx
    Lenovo Legion 7 16ithg6 NM-D721 weird behavior
    by lordmmx
    Hello guys,
    I have recently aquired Lenovo Legion 7 16ithg6 NM-D721, with weird issue. From time to time it will POST fine, boot to windows and work without a single issue. After restart however, it will not post again and then it will not post at all.
    After messing around with bios (reflashing it), removing ssd, wifi, battery, etc, none of helped, I checked 5v and 3.3 coils and to my surprise, multimeter showed both coils hovering around 4V for 5V coil and 2V for 3.3v coil.
    Thermal camera did not showed anything hot, but I'm sure something is either going...
    06-30-2025, 03:54 PM
  • Mohammed Mecegguem
    samsung ue46c6000 weird alternating lines
    by Mohammed Mecegguem
    I encountered an issue with my TV long before noticing a pattern of alternating red lines. Initially, I replaced the T-Con board, but the problem persisted. After a year, I decided to open the TV again and found some oil leaks around the CPU, RAMs, and LVDS FPC connector, likely from the thermal pads. I reconnected the LVDS connector but still faced the same issue with the alternating lines.
    At first, I thought the LVDS cable might be loose. I inspected the cable, found no damage, cleaned the connector, and reconnected it, but the issue remained. This led me to...
    06-19-2024, 01:37 PM
    APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
    This started a few days ago and does this about every 8 hours
    After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
    The battery backup is about 3 or 4 years old
    Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
    06-02-2024, 02:30 AM
  • Benchaton
    Weird Charging behavior Aspire A517-51G
    by Benchaton
    Ok so, I've got a 17" Aspire 5, when I put it under any sort of medium high load it just stops charging and show blinks the status LEDs which I suppose mean it get's in power safety mode. Only notable things I can see being an issue are my CSME firmware which isn't the one from Acer because the Acer one was a vulnerable version relative to the current firmware I have installed (latest for KabyLake / KabyLake Refresh), the PC being only able to supply 0.05W to the battery on load spikes, and the slightly loose power inlet.
    I mostly suspect the latter but it seamingly started happening...
    07-30-2025, 04:43 PM
  • RotVik
    ASUS PRIME B550M-A AC weird behavior
    by RotVik
    Hello, I need a little help
    I got an ASUS PRIME B550M-A AC Motherboard, bad BIOS, it wont display or boot, unless I did CMOS Restart first, after that It will boot but if I modified the configuration of the bios and saved it ,again no image
    I got the BIOS .CAP file from ASUS official support, used a tool called ASUS CAP to BIN, and programmed it to the IC, soldered to the board and got it to boot correctly, all the way to Windows, but now the CPU fan stays at full speed all the time and if I try to power it off with power button it will restart instead, and there are...
    05-01-2025, 04:59 PM
