Re: Sony KD65X85005C, no boot, hdmi IC suspected
In your second picture on the right bottom corner there is a 4 pins unpopulated connector, that is almost surely a serial port, make a picture of that area only, but anyway 1 pin is gnd, at the side, the other side is 5v output, if your adapter doesn't need it dont connect it, the center 2 pins are tx , rx, you must probe at tv start which one has a tension, that is tx and must be connected to rx of adapter. Then set the port at 112500 and open terminal in pc, start tv and watch characters come in, if them are readable, speed is ok if not change speed to a lower. Found the log , turn off tv, set the terminal to record the text, start tv again until it stops sending, then close the file , turn off and upload here the txt file.
