TCL 55S401LHAA No Power
  • Tech06
    • Oct 2018
    • 9
    This TV was Brought to me in non working condition. There are no power\standby lights on the set at all. Here is what I have done so far.
    1. Took back off of the tv and tested that the system was getting AC voltage at the plug.
    2. Tested the fuse on the power board.
    3. Tested the DC voltage at the Large Capacitor.(170Vdc)
    4. Checked for any obvious burn marks bad solder joints.
    5. Unplugged various devices from the main board.(Tcon, Wi-fi module,)
    I'm not getting any response from the set at all. When I measure voltage between the Main Board and the Power Board I am only seeing between .1-.23 vdc on some of the pins. That seems low to me.
    Any Ideas? Thanks in Advance.
  • lotas
    • Jan 2016
    • 4803
    • Russia
    Re: TCL 55S401LHAA No Power
    Power Supply TCL 01-L14TH4-PWB
    • RDC55
      • Dec 2017
      • 180
      Try posting the actual voltage measurements at the P2 connector on the Power Supply with the TV powered up. You need to label the pins as to nomenclature and pin number - unfortunately TCL seems to like to make it hard and put the pin assignments on the back of the boards.
      • Tech06
        • Oct 2018
        • 9
        lotas, Thanks for the schematic. You wouldn't happen to have the entire Service Manual would you?
        • Tech06
          • Oct 2018
          • 9
          With my meter set on 20vdc. I show no voltages on the P2 connector at all.
          • RDC55
            • Dec 2017
            • 180
            I believe even with the Power Supply disconnected from the Main you should still be making 12VDC. The PFC will be about 170 VDC until the main is connected and then it should be about 390 VDC any time the TV is plugged in.
            So I would say time to troubleshoot the Power Supply or find a replacement if it is not making 12 VDC with it disconnected from the Main.
            • Tech06
              • Oct 2018
              • 9
              So to update this. I did end up replacing the power supply a quite a few months back. The power supply was the issue at the time. It lasted less than a year. I now have the set back again this time with a different issue. The unit powers on and I can hear the system click through the menus but, now the backlight is not coming on at all. I thought there may have been a bad safety resistor but, after replacing that I still have no backlight on the set. I think I should just replace the thing at this point.
              • neilc6
                • Nov 2015
                • 1550
                TCLs have lots of backlight failures. Only 2 or 3 rows of LEDs on a TV that size. Panel may also be taped down making the replacement more difficult.
                  • 12307
                  • U.S.
                  guess you were too busy to report back that a new powerboard fixed the tv. PASS.
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                    09-06-2024, 05:59 AM
                    HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                    This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-12-2024, 02:15 PM
                    HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation Specification for Upgrade or Repair
                    This specification for the HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Power 15.6 inch G9 Mobile Workstation PC boardview and ZBook Power 15.6 inch G9 Mobile Workstation PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                    09-07-2024, 05:20 AM
