cello c55sfs4k firmware problem
  • Michaelrobbo
    • Mar 2020
    • 12
    • United kingdom
    bit of a weird one long story short firmware corrupted on my cello tv so wont but into android tried getting a replacement motherboard on ebay but they keep coming with hiya security on them i wrote to cello and they sent me the usb with the firmware on but for the life of me cant get the firmware to load it says to plug in the usb and keep hold of menu on the tv and boot but i get the little robot on the screen then it just boots in to recovery any idea??? the update file name is 6520-0.1.115_boot_and_full_aml_upgrade.img
  • Michaelrobbo
    • Mar 2020
    • 12
    • United kingdom
    Re: cello c55sfs4k firmware problem
    sorry forgot to mention the update file name is 6520-0.1.115_boot_and_full_aml_upgrade.img.user.signed
    • iuliantv
      • Aug 2009
      • 36
      Good evening, I also have a FERGUSON F55SFS4K which seems to use the same mainboard, and it seems we have the same problem, stuck in hiya, and can you give me this software too, thank you very much
      • Lelo23
        • Dec 2022
        • Spojené kráľovstvo
        Hi, can you send me the file?
        • Benass
          • Oct 2020
          • 73
          • Uk
          Hello. I had firmware issue with 65 a bit different to yours.
          This is what I had to do to update Firmware.
          It was send By cello 4 MB bin file in my case.
          To install place in the root of a USB and with the TV off completely (No power)
          insert the USB into the TV USB socket (not the Android USB socket),
          then press and hold the standby button on the TV (not the remote)
          and reapply the power to the TV.
          Upgrade will start automatically and the LED will flash during the upgrade,
          when upgrade finishes it will flash more rapidly,
          then remove the power unplug the USB and reapply the power and turn on as normal.
          altho looks like you have issues with Android system.
          I have followed these steps. TV never turned on. Only standby light was flashing then 30 sec / 60 sec later start flashing faster.
          I hold Stanby button then plugged Power lead into tv. was holding stanby button until more rapid flashing.........
          My tv was different to yours.
          Last edited by Benass; 12-18-2022, 04:36 PM. Reason: my explanation is to flash Bios not android system. Will keep it for the record.
          • Choppadeee
            • Sep 2023
            • Gb
            Hi folks I am looking to gain this firmware. can someone please pm me with a link. I am in the process of writing a bypass tutorial for the hiya issue but would love to see the firmware to have a dig around. cello was on to me and wanted
            Serial numbers. And said they wouldn't help me if the TV was a rental
            No bother because their software is full of spyware
            Heres my board running android TV home
            https://ibb.co/gDL44Ln
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • Awesomerp
              Sencor SVC7020BK robot vacuum cleaner problem
              by Awesomerp
              Hello I have been trying to identify and fix a problem with a robot vacuum cleaner, which when switched on cleans for like 3-4 seconds and stops, all the driving, sweeping and vaccum motors stop.
              On the pcb from a battery connector up to a main microcontroller everything seems to be fine (vcc pin input is 5v constant when a switch is switched on).
              And the switch itself is fine looking at the quality of my soldering
              Red LED keeps blinking during those 3-4 working seconds, and when the robot stops LED just remains lit.
              The green one for some reason does not even...
              09-23-2022, 11:36 AM
            • Slapito
              Request for EC firmware for MSI Vector GP66 12UHSO (MS-15441 ver 1.0)
              by Slapito
              I'm currently repairing an MSI Vector GP66 12UHSO laptop with a motherboard reference MS-15441 ver 1.0. The EC chip (ENE KB9548QF2) on the board appears to be damaged and needs to be reprogrammed.
              Can someone please send me the firmware (EC/Embedded Controller) or indicate where I can download the correct EC firmware version corresponding to this motherboard model?
              I already have access to the BIOS downloads on the MSI support page, but need specifically the EC binary or its equivalent firmware image.
              I already downloaded the BIOS update file from msi official...
              10-09-2025, 02:00 AM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
            • Gibon378
              Problem with stopping audio and video for no reason
              by Gibon378
              PC Specs:
              • CPU: Ryzen 5 1600
              • GPU: GTX 1080 Palit JetStream
              • MOBO: ASRock ab350 PRO4
              • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
              • PSU: XFX 650W (don't remember what model)
              • OS SSD: ADATA SP920
              • OS: Windows 10 21H2
              Problem description:
              Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
              11-19-2022, 09:41 AM
