Sencor SLE 40F82M4
  • peterkos2
    • Nov 2020
    • 43
    • Slovensko
    Sencor SLE 40F82M4
    Hello.
    I recently rummaged in this Sencor TV and found a faulty backlight. I managed to replace 5 LEDs and the TV started up.
    The problem is that the TV restarts itself and I uploaded the FW from the link - it is an older FW than it was there, but it works, only those restarts.
    From what I found, I was surprised- the restart only takes place while watching the three programs every one and a half minutes. Other programs without a problem.
    Has anyone encountered anything like this?
    Can't advise on how to get to the service menu? I didn't find anything specific.
    Further information.
    I found that every minute restarts when watching only three programs is affected by the wifi adapter plugged into the usb port-under the cover from the factory.
    When I pulled it out, the TV runs smoothly.
    If I connect a LAN cable to the TV, the same thing happens.
    But where could be the mistake?
  • Prosatanosz
    Asus B85M-GAMER no hdmi output and random restarts
    by Prosatanosz
    Hi!
    Asus B85M-GAMER absolute no hdmi output (not at start, not at Windows), and random restarts. Everything work, except hdmi and random restarts after 0.1-3 min. Restarts even in bios. On VGA Windows boots up fast, games and apps starts ok. Mem, psu, cpu changed, no luck. I need shematic, because i think the restarts caused by the hdmi failure.
    10-19-2024, 05:27 AM
  • Andri15
    ASUS ROG G513R-MP-VGT 6050A3348202-MB-A02 frequently restarts
    by Andri15
    can someone help me,i have a case for this series often restart.
    After entering Windows for 5 minutes, the laptop immediately restarts.
    is this related to cpu/gpu​?
    04-23-2025, 11:28 PM
  • lawrenceptrini
    Lenovo Ideapad 100-15ibd restarts every few seconds continuously.
    by lawrenceptrini
    Laptop turns on and restarts every 7 seconds or so.
    Power led and Webcam led turn on and goes off repeatedly.
    Pressing the power button does absolutely nothing.
    Same thing happens whether the bios battery is connected or not.
    I tried resetting the bios, press power button to drain power etc.,
    but no change same thing. I tried numerous ram modules but same result.
    Using a desktop power supply I can see the amps going to zero and rebuilding,
    same thing with multimeter. Doesn't matter if I plug in adapter or main battery,...
    12-27-2024, 10:20 PM
  • Jane
    Laptop MSI model MS-16P5 restarts with power supply
    by Jane
    Laptop MSI model MS-16P5, with installed Windows 10, restarts whenever I connect power supply - within a second or two the laptop restarts.
    (Without a charger the laptop works OK.) Another charger behaves in the same way.
    However when windows starts in SAFE MODE, laptop does NOT restart even with connected charger.
    Stop error log is not generated by Windows.
    So I have:
    BugcheckCode 0
    BugcheckParameter1 0x0
    BugcheckParameter2 0x0
    BugcheckParameter3 0x0
    BugcheckParameter4 0x0
    SleepInProgress 0...
    05-03-2023, 04:02 AM
  • televizora
    Too many 16 bit programs running error
    by televizora
    After installing Java Runtime, I have some strange errors on some of my computers. Windows Explorer becomes unresponsive and then strange message pops up claiming that too many 16 bit programs are running.
    There aren't any 16 bit programs on these computers. The OS is Windows 7 x86 SP1 fully updated. There aren't any 16 bit programs running, nor installed. No active instances of NTVDM or anything like this. Seems like it's a problem with UAC/consent.exe/ when trying to elevate the execution of certain programs. But the information about the issue is scarce. Is there anybody around here who...
    03-29-2021, 08:58 AM
