TCL 65S4 Backlight Troubleshooting
  • thelug
    • Apr 2021
    • 3
    Good afternoon, I have a TCL Roku TV 65S4 with a service number of 65S4TDAA. I searched and didn't find any posts about this TV.
    Device was working properly no issues. One day screen randomly went black. I noticed ghosting symptoms of the back light being out. I power cycled and was doing some troubleshooting and it turned back on and was fine for 6+ months. It went out again last week and won't turn back on like it did the first time. Sound and picture as expected, just no back light. I have tried the reset and power drain steps. If I fully drain the power when unplugged, when it is powered back up it will power the backlight and the TCL logo shows and appears to work then immediately (less than 2 seconds) the lights turn back off. I got a known working power supply board from another TV and tried swapping it and the symptoms are still the same. Since the sound and picture still work, I don't believe it is a TCONN board, but since the lights turn on after a power cycle, I am hesitant to think it is the back lights themselves, but I am a computer guy not a TV guy. I am comfortable with boards and ribbon cables etc, I have replaced TCONN and power boards before successful, but this is my first possible bad backlight and wanted to know the best troubleshooting steps since the light turn on for a moment then off. Any help would be greatly appreciated.
  • neilc6
    • Nov 2015
    • 1550
    Re: TCL 65S4 Backlight Troubleshooting
    Backlight issues are almost always caused by bad backlights. Protection circuitry is kicking in to shut them down because an error is detected. https://techhometravel.com/lg-ln-ser...ed-backlights/
    • thelug
      • Apr 2021
      • 3
      Thanks for the info... So that is LG specific and also mentions the Samsung and a few others. Is it similar for the TCL? Can I find a repair / disassembly guide for my TCL version? I see mixed info on if it's worth replacing on bigger TVs.
      • neilc6
        • Nov 2015
        • 1550
        Very difficult to disassemble a 65 inch panel without damaging it. Suction cups may help. All tvs are very similar. Differences will be if screws are used versus clips and if double sided tape is used. You may find a video for TCL models if you search.
        • JohnyRuffneck
          • Apr 2022
          • America
          Hello there,
          I'm dealing with the same situation myself , I'm wondering if you had luck with it.
          • Storyteller12
            • Jun 2020
            • 625
            I just replaced the backlights in this model. It’s definitely the backlights causing your issue.
            The screen is difficult to get out since they used double sided tape. Have to be careful not to break the screen removing it.
            Other than that it’s straight forward backlight repair.
            • triplefour
              by triplefour
              09-13-2023, 10:43 PM
            • phuzzyday
              Sony 70" 70X690E - It's now a divorce risk! (6 Months on kitchen table.) New power board installed! STILL trouble!?!?
              by phuzzyday
              For masochists who want to see some of the crap that I have been through already... (Truly optional now though, all those trees were barked up for no reason.)
              https://www.badcaps.net/forum/troubl...klight-circuit
              I started a new thread to get a fresher look at things, even with eyes that looked before. It's different now!
              So I got this on Facebook for $66US, blank screen. Just reseated all...
              09-08-2025, 05:53 PM
            • Comp_Pro
              No Backlight Macbook A1990 820-01041
              by Comp_Pro
              Hello all,
              Am trying to figure out this backlight issue with this A1990 Macbook Pro.
              Tests performed:
              There is no backlight even with a good screen.
              Backlight IC is receiving the correct support voltages.
              Fuse F8400 ok
              Current sense resistor R8400 ok
              Backlight IC is receiving 3.3V on enable pin.
              Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
              Backlight IC receiving 5V from PP5V_G3S
              Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
              I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
              05-06-2024, 10:23 PM
            • canadaboy25
              LG Flatron 24EN33TA No Backlight When Cold
              by canadaboy25
              I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
              I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
              03-07-2023, 12:23 AM
            • gabrielA7
              Macbook pro A1706 / Backlight flex cable compatibility
              by gabrielA7
              Hey guys!!
              I’ve got a question here!
              I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
              Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
              Here’s what the bot told me:
              I said to him: “I’m going to install the 821-01229-A.”
              ChatGPT replied:
              Understood — but before you solder or install the 821-01229-A,
              11-11-2025, 03:26 PM
