Screen Replacement/Samsung UN32J525DAF
  • Wirenut420
    • Jul 2020
    • 4
    I have searched for this model number here and have drawn a blank. I have recently acquired said unit and the screen is broke. I had to buy an AC adapter for it to find out. It works when I turn it on because I can see some stuff. I really like this little unit and wouldn't mind finding another display for it. I know I'msupposed to pop the cover off to get the display number but I can'r quite get it open. Any help is way appreciated and thank you!
    • 12314
    • U.S.
    Re: Screen Replacement/Samsung UN32J525DAF
    Usually there's a screw that someone missed, look it over. If there's no screws it may be similar to this one: https://www.youtube.com/watch?v=oNqJppoV5S0
      • 12314
      • U.S.
      Another there: https://www.youtube.com/watch?v=yqS99vd-9o8
      • Wirenut420
        • Jul 2020
        • 4
        Thank you very much! Now that i have a little time I shall pop that sucker off and get the number and check availability, then maybe chuck it.
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • ScHAmPi
          Samsung UE48JU7000 screen issue after backlight replacement
          by ScHAmPi
          Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
          I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
          07-15-2024, 05:41 AM
        • FreakyMex
          Trouble to identify part (Lunii screen) for replacement
          by FreakyMex
          Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
          I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
          02-17-2025, 01:16 AM
        • Chrissygizmo
          samsung galaxy ao2s very temperamental after screen replaced
          by Chrissygizmo
          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
          Ive eventually managed to get it on and working but it's very temperamental...
          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
          05-26-2024, 12:05 AM
