LG 32LC7D No Video or Audio
  • BBoles
    Hello Everyone, I am new to the site and was looking for some help with my LG LCD TV. The unit has been shutting down occasionally at first and now does not have video or audio. The power light turns green and flashing for about 15 seconds when turned on and then normal green LED indication, but there is no audio or video. I still work in the electronic field but haven't opene up a tv in about 15 years. Anyhow I am starting at the power supply and have it pulled but not sure how to check it on the bench. I have the ac power applied and the 5v+ is available on the connector points but not sure how to tell it to power up the rest of the power supplies. No 3.4v, 6.5v or 12v, I would appreciate any help.
    Thanks,
    BBoles
  • tmwalsh
    • Jan 2009
    • 119
    Re: LG 32LC7D No Video or Audio
    In most cases, it is almost impossible to bench check a power supply unless you provide adequate loads on the outputs. That said, most power supplies take a signal in the 5v range to enable them. Or they need one of their pins pulled to ground for a short period.
    I would have tested the outputs while the supply was still mounted to the rest of the set if at all possible. And would have monitored the signal pins to determine what happened when the 'on' button was pressed, to verify that the PS was being told to start up.
    If you take a look around this site, you will notice the emphasis on electrolytic capacitors. They have become a 'cottage industry' for those that can replace them. Inspect your for leaking electrolyte, tilting & separation at the base and for bulging tops. Many brands have been brought to market in the recent past, and some have developed a reputation as being food for the recycler... after short lives.
    tom
    • BBoles
      Thanks for the response.
      Work is good they been keeping very busy and long days. I am thankful.
      I have performed some static checks on the components on the Power Supply and caps, diode, chokes and fuses check good no appearance of damage or cracked leaking capacitors. I reinstalled the power supply and took some voltage reading to ground pin on connectors, with the set on and off. I am going to try and attache my result see if anyone can see more than I understand. Woops not sure how to do that. I will list my findings.
      P201 off on P202 off on
      1-ACD 5V 4.9V 1-19V 0V 0V
      2-ON\OFF 0V .6V 2-19V 0V 0V
      3-ST5V 5.1V 5.1V 3-GND 0V 0V
      4-GND 4-GND
      5-INV/CTL 0V .7V 5-6.5V 0V .7V
      6-ERR .68V .68V 6-GND 7-BURST 3.2V 3.2V 7-3.4V 0V 3.4V
      8-ST5V 5.1V 5.1V 8-GND
      9-GND 9-12V 0V 0V
      10-A-DIM .84V .92V 10-GND
      11-6v 0V .74V
      12-GND
      13-3.4V/ON 0V 2,4V
      Thanks,
      BB
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
        HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC E6300 Specification for Upgrade or Repair
        This specification for the HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC boardview and Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will...
        09-12-2024, 03:36 PM
        03-31-2024, 02:12 PM
      • samson7point1@yahoo.com
        Help troubleshooting an audio problem with an RCA SGT-250 CED Player
        by samson7point1@yahoo.com
        The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
        The player processes the audio signal using two different reference frequencies. The "R"...
        04-30-2024, 11:22 AM
