60" LG 3D White Reflector Sheet
  • 27grains
    • Feb 2021
    • 18
    I have the TV apart, What is the procedure to remove the paper thin white plastic reflector sheet without ruining it? The sheet is glued on almost everywhere.
    Alcohol works on the edges, but the area over the LED Strips is extremely difficult. Is Acetone too strong? I don't want to melt the plastic.
    What chemical will work?
    Would a heat gun work or hair dryer?
    Thank You.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: 60" LG 3D White Reflector Sheet
    I would think a hair dryer would do the job.
    • neilc6
      • Nov 2015
      • 1550
      I did one of these 60LN series and never again because of the glued down sheet. I would cut the strips out with a knife.
      • 27grains
        • Feb 2021
        • 18
        Please tell me how you removed the glued reflector sheet?
        This is my 3D TV LG60LA6200UA, I can't replace it. Time doesn't matter.
        I mix Acetone and 90% isopropyl alcohol for flux remover. I don't know if acetone will melt the sheet.
        Is the glue water soluble?
        • alfatv
          • Sep 2020
          • 353
          Try to replace LED with sheet on.
          • neilc6
            • Nov 2015
            • 1550
            I would score along the strip and heat up the double sided tape under the strips. The thick lens strips use extra sticky glue. Without softening the tape, you would need a scraper and hammer.
            • 27grains
              • Feb 2021
              • 18
              What type of double sided thermal tape is used to mount the LED Strips?
              • 27grains
                • Feb 2021
                • 18
                I am learning, everything is glued together, the white plastic Reflector Sheet is glued to the metal frame everywhere, under the Reflector Sheet the LED Strips have plastic round reflectors at each LED Bead & Filter Bead, it is glued to the strip and to the reflector Sheet.
                What I discovered is 100% Acetone will remove the glue and not damage or melt the Reflector Sheet. This is my Learning TV, I have removed all he circuit boards, switch and replaced the screws, I have a metal sheet with plastic glued to it, nothing to get damaged. I will use Acetone only outdoors.
                I wish I would have tried Acetone first, Goo Gone was a mess. Half done.
                • 27grains
                  • Feb 2021
                  • 18
                  I received an email telling me to use a hair dryer to heat the plastic sheet to release the glue being careful not to overheat and damage the plastic sheet.
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • lfhlaw
                    60LN5600 white reflective sheet
                    by lfhlaw
                    So I had to replace the LED lights on this TV and that worked out nicely. But the White reflector sheet that helps to diffuse the led lights evenly was glued into the back chassis which had to be removed to replace the LEDs.
                    Placing the white reflector sheet caused it to not sit evenly - causing weird diffusing when TV was all put together. Picture is still decent, but now there are dark and light spots due to the white reflector sheet not sitting against the back chassis.
                    Anyone have thoughts on replacement white reflector? or do I just scavenge broken TVs for...
                    05-23-2022, 07:14 PM
                    MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                    This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                    09-06-2024, 07:46 AM
                    MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                    This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                    09-06-2024, 07:29 AM
                    MSI Prestige P65 8RF Creator White Notebook P Specification for Upgrade or Repair
                    This specification for the MSI Prestige P65 8RF Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF Creator White boardview and P65 8RF Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-06-2024, 07:25 AM
