Will putting a TV on an automated power switch kill the PSU over time?
  • Jeryswan
    • Mar 2020
    • 39
    Hey everyone!
    This question is not quite repair related but since I'm a tech and can't help thinking like one, I wanted to get some other TV tech opinions.
    Long story short I own a repair shop and I am trying to set up a power circuit to turn on 3 TV's automatically every morning and off every evening. I will be using a Zwave 15 amp switch so I can add it to my existing business automation hub.
    Here is the exact switch:
    https://www.energyavenue.com/Leviton...8aAh-AEALw_wcB
    My question is this: If my automated switch cuts power off to these TV's every evening, will that damage the PSU or any other component? I know if you turn a TV off with the controller or the button on the TV that it puts the TV into low power mode/rest mode in most cases depending on if the model has any advanced power setting within the GUI. But since I will only be powering off theses TV's by cutting power to outlet, is that going to cause any problems over the long run? I know it probably wont hurt the TV over the course of a couple weeks but what about over the course of a couple years? Ultimately, I don't want to build a system that is going to fail in the future. And yes, I know I can get and program a RF system to turn these TV's off with their actual RF reciever's but I want to start with the 1st option because I already have the existing infrastructure.
    TIA
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Will putting a TV on an automated power switch kill the PSU over time?
    My upstairs TV sits on a power bar. It gets turned off and on several times a day using the power bar so the TV is completely off and not in standby. It's been like this for 5 years now with no apparent problems.
    I also do this for my main PC. When it's not in use, I turn it completely off via power bar switch. I have been doing this for 15+ years and never had any PSU problems.
    --- begin sig file ---
    --- end sig file ---
    • jjanssen7
      • Nov 2012
      • 252
      Interesting question... I've always wondered the same.
      • Diah
        • Feb 2013
        • 6613
        the OP post write TV's ( more than one set ) the answer at post 2 was for one TV and one Main PC booth are separated.. . here we are in trouble if one set of this TV's group got defect at any reason, will caused load current., even if the other will effected by 1%. we need to drop this 1% to ZERO by connecting the main timer line first to AC voltage stabilizer and then to TV's, it will take care of TV's in case this matter happened.
        • Powderfanupnorf
          Dell AL440LX power on switch circuit help required
          by Powderfanupnorf
          Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
          So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
          My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
          06-24-2024, 01:24 PM
        • grimacelord
          NEC TurboExpress On/Off Power Switch Replacement Help
          by grimacelord
          I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
          I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
          I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
          11-09-2023, 09:49 AM
          09-06-2024, 05:59 AM
        • CdDvdFlash
          LTL Acorn 5210A Trail Camera Power Switch
          by CdDvdFlash
          I have an LTL Acorn 5210A trail camera and the power switch needs replacing, there is only one site I found that sell them but they want 12 pounds each I'm in Australia so thats $24 but I see these switches are in all sorts of devices everywhere so I'm hoping to find a cheaper one, I dont know what the pinout is for these switches but I have taken apart the camera down to just the board and removed the switch and hooked up a battery pack (4x AA batteries) to see what the voltages are at the traces where the switch was. In the picture of just the switch it is currently in the off position, it moves...
          08-06-2023, 09:12 AM
