SONY KDL 43w805c does not accept commands
  • Diah
    • Feb 2013
    • 6438
    Re: SONY KDL 43w805c does not accept commands
    Originally posted by Dobsuk
    Yeah, i found the same but it looks it does not work. And can see the comments under the post, seems nobody has success with that rollback
    I tried and using your advice, Diah
    It looks i need to looking to buy Main board
    no need to buy new mainboards...
    take out the heat sink of the CPU and show what we have under it
    • Diah
      • Feb 2013
      • 6438
      by the way... when it start at select language did you hear the music ? if yes you increase the volume or decrease from side panel... is there response and did you have notification bar ?
      • Dobsuk
        • May 2020
        • 127
        • England
        Yeah, i can hear the music and the volume responds but cannot see notification bar every time. But he volume is working - i can turn it up or down even i can or not see the notification volume bar.
        • Diah
          • Feb 2013
          • 6438
          take out the heat sink... it need heating to repair the BGA ... by removing the heat sink we can tell from which side (PIN ) on ship are responsible
          • Diah
            • Feb 2013
            • 6438
            one things more before we go for heating... your photo https://www.badcaps.net/forum/attach...5&d=1610728654
            the side panel and led indicator IR receiver socket... are they connected with ribbon flat cable to the middle of the mainboards?? if yes... did you inspect under loop the end silver pins of the cable if any short or broken ???? yours issue very strange
            • Dobsuk
              • May 2020
              • 127
              • England
              #26
              This is it:
              • Dobsuk
                • May 2020
                • 127
                • England
                #27
                No, they are not with ribbon cables:
                • Diah
                  • Feb 2013
                  • 6438
                  ok then heat this chip with hot air gun specially the middle to left side facing the plug which goes to side panel
                  when you heat it try dont move the boards ...leave it cool then put it back
                  • Dobsuk
                    • May 2020
                    • 127
                    • England
                    #29
                    I did in #27
                    • Dobsuk
                      • May 2020
                      • 127
                      • England
                      #30
                      For how long i need to heat it?
                      • Diah
                        • Feb 2013
                        • 6438
                        which heat equipment do you have ? show me to let the work being perfect this area i mean
                        • Dobsuk
                          • May 2020
                          • 127
                          • England
                          #32
                          Errmm, that is the problem. I do not have proper electronic hot air gun. I've got one bigger and i am not sure if i can use it for that.
                          • Diah
                            • Feb 2013
                            • 6438
                            dont worry LOL.... do you mean the one used for Pipe sanitary?
                            • Dobsuk
                              • May 2020
                              • 127
                              • England
                              #34
                              Haha, no not for pipes I think i can use my one:
                              • Diah
                                • Feb 2013
                                • 6438
                                okay ... but you need first to cover all around the chip for example the glue plaster used by wall or car painting... to avoid the blow hot air fly one SMT parts near to the chip.
                                after that let this gun to the maximum heat ,,,let it run far from the board until it reach the high temperature if it was 350 degree, then face it to the chip area and calculate 6 second .. such 11 , 12, 13, 14, 15, 16 then leave it cool down
                                • Dobsuk
                                  • May 2020
                                  • 127
                                  • England
                                  #36
                                  Done! Now i need to find my thermal paste
                                  • Diah
                                    • Feb 2013
                                    • 6438
                                    try it before you apply the paste
                                    • Dobsuk
                                      • May 2020
                                      • 127
                                      • England
                                      #38
                                      Can i try it without this heat sink just for 1min?
                                      • Diah
                                        • Feb 2013
                                        • 6438
                                        you can for more than 10 minute too
                                        • Dobsuk
                                          • May 2020
                                          • 127
                                          • England
                                          #40
                                          Nope, it is absolutely the same Shall i heat it again?
                                          • crackedprint
                                            Sony HCD-HX80R Amplifier Volume Control Problem
                                            by crackedprint
                                            I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                                            I have tried a Cold Reset as per the service manual.
                                            I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                                            I have looked all the way through the service manual and tried many online...
                                            01-21-2025, 12:18 PM
                                          • karthur
                                            Vizio D65x-G4 Volume changes on its own
                                            by karthur
                                            On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                                            It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                                            06-05-2025, 08:13 AM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • ahmedtou
                                            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                            by ahmedtou
                                            help me please
                                            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                            I will share all the details with you, including the disc information.
                                            Code:
                                            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                            Current Profile: BD-R
                                            Disc Information:
                                            Status: Empty
                                            State of Last Session: Empty
                                            Erasable: No
                                            Free Sectors: 12,219,392
                                            Free Space: 25,025,314,816 bytes
                                            Free Time: 2715:27:17 (MM:SS:FF)
                                            Next
                                            08-27-2025, 08:49 AM
                                          • Ruptor
                                            Sony MHC 6600 volume clicking
                                            by Ruptor
                                            Has anybody had the problem of the digital clicking from the volume control coming through the speakers. I guess the mute should activate as everything seems to have a mute from the analogue switch LC7822 to prevent output of stuff on the speakers but the mute circuits are really complex. The pcb is very badly manufactured as if it is over etched and not cleaned properly before being screen printed because I have fixed one fault but a wide track lifted off real easy with very little heat requiring extra repair. I dread touching the board so would like to go straight to the problem if someone has...
                                            05-21-2023, 05:32 AM
