SOVOS Flip down TV SVKTV156A
  • barry wilkins
    • Aug 2009
    • 172
    Hi has any body got any info on this LCD TV?
    Something is dragging down the 12V power supply ,looks like a severe overload
    thanks
    Barry Wilkins
  • zens electronics
    • Jan 2021
    • 31
    • uk
    Re: SOVOS Flip down TV SVKTV156A
    Hi Barry
    With the TV disconnected from mains , carry out a continuity test from GND to the 12 V rail .
    If low , the method i use for quick diagnosis , would be to diconnect source of rail , then feed in a low supply to start with , maybe a few volts from an external bench supply , obviously with TV still off .
    If current draw ramps up quite considerably as you gradually start to increase supply , then check to feel which component is running very hot .
    I normally cover the board with freeze spray , as it's easier to spot which component begins to heat up .
    • barry wilkins
      • Aug 2009
      • 172
      Hi it is not mains driven ,it has a 12volt power supply , as I am not much up on LCD tvs ,beginning to think it could be the back light.
      So I will take a look at that.
      Barry
      • zen
        • 511
        Hello again Barry
        Have you tested TV with another power supply .
        Had these types of supplies , give up under load .
        • barry wilkins
          • Aug 2009
          • 172
          I tried another 12 supply it still shut down.
          I think this has been repaired before, the capacitors on the board are normal type and have been glued down .they are far too big ! .
          Looked like a burn up under this lot,when I managed to remove this mess I could see the capcitors should have been surface mounted type ,which are much smaller.
          There was a component on the board that looked very poorly I could not determine what is was,, it measured a couple of ohms.
          I powered the board up today and it started to burn up ,what I had been looking at was a surface mounted capacitor,quite a bit of damage to the board so a bit of work to fix it.
          There are two surface
          Barry
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Post some photo's. It could be helpfull.
            • Diah
              • Feb 2013
              • 6435
              Originally posted by barry wilkins
              you know what.. i would like to encourage any one with less sources of equipment's to put his hand on the first PC power supply he got before or later.. they will give you enough watts of any line we need 3.3V & 5V &12V. so all in one,
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
                03-31-2024, 02:12 PM
                MSI Summit E13 Flip Evo E13 FLIP EVO A11MT-018AU Hybrid (2-in-1) Specification for Upgrade or Repair
                This specification for the MSI Summit E13 Flip Evo E13 FLIP EVO A11MT-018AU Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E13 FLIP EVO A11MT-018AU boardview and E13 FLIP EVO A11MT-018AU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                09-07-2024, 04:10 AM
                MSI Summit E16 FLIP EVO A13MT-262BE Notebook E16 Flip Evo Specification for Upgrade or Repair
                This specification for the MSI Summit E16 FLIP EVO A13MT-262BE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E16 FLIP EVO A13MT-262BE boardview and E16 FLIP EVO A13MT-262BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-07-2024, 06:38 AM
                MSI Summit E16 FLIP A13VFT-020BE Hybrid (2-in-1) E16 Flip Specification for Upgrade or Repair
                This specification for the MSI Summit E16 FLIP A13VFT-020BE Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E16 FLIP A13VFT-020BE boardview and E16 FLIP A13VFT-020BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
