Devant 32DL421 not working
  • cma1084
    • Nov 2020
    • Philippines
    Hi everybody! So here's the background. I have a TV that I use for myself since the kids use the main TV. I use it mainly for my Nintendo Switch or if I want to watch something and the kids are using the other TV.
    So initially the TV's LED lights fail and I purchased the exact replacement lights for it and I replaced all of the 3 strips at once. So it worked for a few months and I let my sister in law borrow the tv. As it happens it breaks in her care. Now I'm not saying she broke it...but things usually tend to brake when others use it. Go figure.
    Anyways, she said that they were watching movie, then the screen slowed down/movie slowed down, then screen image split and at this point they turned off the TV. They tried to turn it back on and it wouldn't.
    So I took a look at the board, did some multimeter testing and 'maybe' found two SMD capacitors that may be bad. But I have no real experience with these so it may or may not be the culprits or something else maybe. Nothing else on the board looks defective.
    I found the exact same board for sale and it was really cheap so I bought one. Now this one, kind of works. The TV standby light turns on but the TV itself won't come on. No LED lights, no sounds, nothing. Unlike the first board this one at least has the power light come on. The only thing I noticed is that this one has a high pitched noise coming from it. So I read somewhere here on the forums that it maybe a bad capacitor near the power supply.
    so that's where we are now. Two boards - both defective. I think both can be repaired though. I just can't figure out what I should be checking. Image below is what the board looks like. Not mine, but I will post the pics once I figure out how to post them here.
  • koriwi
    P14s Gen 2 AMD; no boot, no image, no backlight, no charge
    by koriwi
    Hi guys, I am new here, but I've tried my best to read up on the beginner guides and reading some other threads. So here the base information i can provide.
    -Lenovo P14s Gen 2 AMD
    -Ryzen 7 5850u
    -16GB soldered (32GB stick added, removed for debugging)
    -256GB SKHynix SSD (removed and swapped for debugging)
    -NM-D451 Motherboard (P/N: 5B21C82277)
    -S/N: PF-34N64A
    -Model: 21A0-000QGE
    History and symptoms:
    I had this Laptop for some time but stopped using it (installed Linux, worked perfectly) as I changed company and got a MacBook...
    03-08-2025, 05:22 PM
  • Francesc V.
    Christmas lights - Something I am doing wrong
    by Francesc V.
    Hi:
    i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
    I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
    If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
    Could...
    03-11-2023, 07:38 AM
  • bialag
    Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
    by bialag
    I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
    Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
    03-25-2025, 05:56 PM
  • kjchatman
    playstation 5 crashes and cuts off while trying to playback a dvd movie
    by kjchatman
    the disc drive works perfectly because i can install games with it and it can read the movies.I can never get it to playback a movie disc. it goes to a black screen and sometimes a green screen then the console shuts down. It does it every single time i try to play a movie. The games also do the same thing If I don't start them up immediately after the console boots up. I've tried factory resets and replacing the ssd controller and the southbridge but nothing has resolved the issue
    11-11-2024, 06:52 PM
  • gabrielA7
    IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
    by gabrielA7
    Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
    I saw that the room LED lights up only when the screen is connected, so quiet.
    We have all the power supplies, even processor, 1.8V
    One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
    I suspect that there may be some leak in the processor.
    Anyway, when I press the power, it...
    10-29-2024, 06:48 AM
