Sony BB8 main board fix
  • R666
    • Jan 2020
    • 18
    • Spain
    I have a Sony KD-65XE7096 (XBR-65X70E in some regions). This TV was refusing to turn on and showed a 2 blinks error code. After replacing the main board now the TV is fixed.
    I would like to fix the main board itself. This board is the model BB8 and has the following id's/part numbers:
    1-981-926-22
    172657422
    A2184797C
    Googling for this board I've found a document called "Main board FY17 4K GN3UN-BB8 Easy Repair Guide_(GN3UN)", but I haven't been able to download it. Does anyone by any chance have it?
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • JDC
    (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
    by JDC
    ONN 100012588
    Issue: No Power, Then Rebooting After Main Board Change
    Short answer: replace main board and power board
    Technical answer: replace main board and Q306 & Q307 on power board.
    Long answer:
    TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
    07-15-2022, 07:39 AM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
