Philips 37PFL9903\10 Q529.1E Display Code
  • trunks81
    • May 2020
    • 265
    • Nederland
    Hello
    Iam having an issue and i cant solve it, This tv had an defective mainboard type 310432858531, so i ordered an other mainboard which should work according the seller 310432854945.
    The Display code in that board is 141 according to the sticker on the back it should be 161, Only problem when i enter that code i dont have an image any more. So i did change the display code back to 141
    So i also changed the option group 1 and group 2 codes arcording the to service manual when doing this the tv goes into reboot mode.
    So i did the manual SDM mode with an jumper wire and changed all codes back, the issue stays that the iamge is flickering.
    Iam out of options who has an idea ?
  • Diah
    • Feb 2013
    • 6396
    Re: Philips 37PFL9903\10 Q529.1E Display Code
    write code 161 again then re flash firmware
    • trunks81
      • May 2020
      • 265
      • Nederland
      Hello Diah when i change the code to 161 the tv does an reboot loop, So flashing is not possible i think
      The tv option code are set like on the pictures matching code 141.
      Edit i also uploaded all the stickers in the set or on it
      Edit finally managed to update to the to the lastest version
      But the set keeps flickering ?
      edit found the problem the smps needs to be modified.. now i need to find which parts
      • Diah
        • Feb 2013
        • 6396
        edit..
        • eurgenca
          Philips TV 43pus7505 setting display option code, help please.
          by eurgenca
          Hello.
          I am dealing with a Philips TV, 43pus7505 and is stuck on boot loop.
          So I ordered a used CPU board, and now I have wired picture.
          I think the problem lies in display option code. According to SM, the command for setting
          display code is 062598 + MENU + 032 (032 is written on a label on back of a TV).
          But as soon I press the menu button TV jumps in menu. Can someone please tell me what I am doing wrong,
          or can I manually edit option code in SAM.​
          10-07-2024, 02:09 AM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • lanovey
          SF314-41 BIOS without internal display
          by lanovey
          Hello there,
          I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
          I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
          06-13-2025, 02:38 AM
          LCD LED TV Service Menu Codes
          ALL LCD LED TV SERVICE MENU CODES
          Service Menu Code with Board Name
          China Universal Board / Jumper Board Service Menu Code
          Changhong Ruba Service Menu Code
          Ecostar LED TV Service Menu Code
          Orient LED TV Service Menu Code
          Haier LED TV Service Menu Code
          TCL LED TV Service Menu Code
          Samsung LED TV Service Menu Code
          LG LED TV Service Menu Code
          Videocon LED TV Service Menu Code
          Supra LED TV Service Menu Code
          Toshiba LED TV Service Menu Code
          Symphony LED TV Service Menu Code
          Veste/ LED TV Service Menu Code...
          10-31-2024, 03:58 AM
        • Rangry
          Razer Blade 15 2022, No internal display, Error Code 43
          by Rangry
          Hi! I have a Razer Blade 15 2022, with a RTX 3060.
          One day, while using Linux, the internal display suddenly stopped working.
          On Windows, it says that the internal GPU has stopped working (with error code 43).
          I have tried removing the coin cell and the battery, and replacing the RAM, with no success on fixing anything.
          I'm looking for directions to fix this problem, and, first of all, I would like to be able to access the BIOS and change some settings (which is currently impossible as it is always shown on the internal display). There is a setting...
          05-29-2025, 07:01 AM
