Samsung UE40D5520RKXXU USB Problem
  • Bloopeta
    • Jun 2018
    • 526
    Samsung UE40D5520RK with a USB Problem, when put a USB device into either USB port, message comes up on screen as usual saying USB device (and the name of device) detected. Click to open, and screen goes blank, all buttons on remote or TV become unfunctional, have to unplug to restart, whether USB device is removed or not.
    Have tried factory reset, have opened up and reset eeprom.
    Any help greatly appreciated
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung UE40D5520RKXXU USB Problem
    Have you formatted the USB drive as per the user manual. I think it has to be formatted as FAT16 but I'm not 100% certain. Also is there a limit to the USB drive size for your set.
    • Bloopeta
      • Jun 2018
      • 526
      Ah, do you happen to know the limit of the size please??
      That could be it, as its a 64gb USB and its close to capacity
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Post #6 has the USB drive formatted as FAT32
        https://www.badcaps.net/forum/showthread.php?t=58112
        Also the USB drive should hold the firmware only and nothing else.
        • Bloopeta
          • Jun 2018
          • 526
          Ah im not trying to update it from USB, yes the drive is fornatted fat 32, it contains video files to watch. The usb works fine on various other TVs, just not this one
          • diif
            • Feb 2014
            • 6978
            • England
            What format are the films ?
            • Bloopeta
              • Jun 2018
              • 526
              Various, some avi, mp4, etc
              • diif
                • Feb 2014
                • 6978
                • England
                It should play Divx, Xvid and HD mkv, I'd suspect the NAND if it isn't, it's a D series.
                • Bloopeta
                  • Jun 2018
                  • 526
                  Thats what I was afraid of, I was hoping there was maybe a reset to do other than what Id already tried :/
                  Thanks for your help
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    They aren't hard to replace, they are around £20 on ebay programmed or £2ish blank and a programmer for them around £100.
                      09-07-2024, 05:50 AM
                    • howardc64
                      Samsung UN55JU650DF network/streaming problem
                      by howardc64
                      Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                      This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                      07-09-2025, 12:44 PM
                    • ja1870
                      Intermittent Samsung H4000 TV A/V problem. Failing component, or "reset" fixable?
                      by ja1870
                      As probably no symptom is unknown to those around here, would appreciate any comments.
                      Trying to troubleshoot an intermittent condition for a non-technical senior - remotely.
                      When I can get over there, will try a factory reset, but suppose it could be a symptom of a failing cap or other component - and prefer to be forewarned either way, if possible.
                      Detail:
                      Older 28" (non-Smart) flat screen Samsung UN28H4000AFXZA works perfectly, except when occasionally displays one of two - probably related - symptoms.
                      1) Channel displays...
                      03-15-2023, 05:17 PM
                    • alro7779
                      Samsung UN55MU6103F video problem; has colored stripes on the display
                      by alro7779
                      Hello, everyone!
                      A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                      09-27-2025, 11:29 PM
                      09-06-2024, 11:40 PM
