Vizio D50f-E1 doesn't turn on
  • alfatv
    • Sep 2020
    • 353
    Nothing happens visually when plugged in.
    Holding power button same result.
    Power supply generates 30V for backlight and 19V for main board.
    I found feedback resistors for 19V and figured out it's correct.
    On the main board, lots of other voltages are present: 5/3.3/1.5/1/2V
    Panel voltage is missing (assume CPU doesn't enable it) and ON signals to PS are low (close to 0V)
    CPU is warm.
    Connected ethernet cable, the router doesn't recognize TV.
    I suspect it's bricked or BGA, but would like to get some opinions.
    If someone could share service manual, it would be great.
    I did find one for E series which helped with power supply troubleshooting.
    Also, can I use main board from same series, but different screen sizes?
  • alfatv
    • Sep 2020
    • 353
    Re: Vizio D50f-E1 doesn't turn on
    Update:
    There is PS_ON 3.2V coming back from main board which enables backlight PS.
    But backlight on/off and dim inputs are all zeroes, so backlights are off.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • cheeky2
      by cheeky2
      05-25-2024, 03:27 AM
