Samsung UN58J5190AFXZA pwr supply troubleshooting help
  • neilc6
    • Nov 2015
    • 1550
    Re: Samsung UN58J5190AFXZA pwr supply troubleshooting help
    This model looks very similar to UN58H5202Af (1 year older) where bad backlights take out a FET.
    https://www.badcaps.net/forum/showth...ht=un58h5202AF
    Check Q9101? (similar location) for shorts.
    • momo2000
      • Oct 2017
      • 20
      Any other suggestions on what to test to track down the failed component(s) in this power supply? Would love the satisfaction of fixing it "myself" but I guess will have to go buy a new TV if I don't have this solved in the next few weeks. Suggestions appreciated.
      • bstewara
        • Jun 2019
        • 40
        We're you able to determine the part number for QM801 and 802CS MOSFETS?
        I have a set that these MOSFETS failed and burnt so I can't see the part numbers.
        Thanks in advance
        • MtnManMike
          Samsung UN75J6300AFXZA LCD TV Power Supply Troubleshooting
          by MtnManMike
          I'm hoping to get some help figuring out how to troubleshoot this power supply board. The television is a Samsung UN75J6300AFXZA, version no. UH03. The power supply board has two model numbers on it, L75S1 and BN44-00723C. As far as experience level, I'm familiar with recapping boards in terms of safely going through the soldering motions, choosing suitable replacement parts, and so forth, but as far as understanding the various functions of each part of these TV power supply boards, I am a rank beginner.
          When I plug the TV in, the screen flashes on and off and...
          07-23-2022, 06:43 PM
          09-07-2024, 05:50 AM
        • cheeky2
          Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
          by cheeky2
          This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
          I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
          Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
          06-15-2025, 05:12 AM
          DVR camera recorder switching power supply capacitor failure really
          These cheap non brand capacitors at it again
          Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
          Well at least I have the cameras back on line I to try the...
          01-22-2022, 06:28 PM
        • shovenose
          Ubiquiti Unifi PoE Switch US-8-150W Power Supply Failure
          by shovenose
          Got this one for free because, well, it no worky.
          A little research and there are tons of complaints all over forums/the internet about premature failure of these switches. The observation everyone makes about these is "they run hot" and failure occurring as soon as 13 months, right out of warranty, of course.
          Upon removal of the cover I found a G0398-15011480A power supply that, when plugged in, was making a constant ticking noise. Multimeter confirmed the PSU was the issue. Output was cycling between 0 and about 20V. With output disconnected it sat around...
          08-11-2021, 01:26 PM
