OLED55B6 - screen goes blank intermittently sound keeps on
  • shaileshpandit
    • Aug 2020
    • 5
    • India
    On my OLED55B6 screen goes blank intermittently sound and remote keeps working fine https://youtu.be/paHY_MLtHdQ
    This happens while on home screen too. This got worse as time passed by, these days screen just remains on for short period. attached boards and connectors images.
    mainboard and power board seems ok as PWR_ON DRV_ON 12VT_ON control signals from MB and 12VT, 12VM, 24VS, 24VD power outputs are working as expected.
    Have detached and reattached most of the connecters except PANEL to TCON and LVDS MB side connections, for LVDS MB side, do i have to open the locks from left to right upwords?
    Haven't opened TCON heatsink yet, but if i open it what all things i can check? can this be PANEL/TCON/MB issue? also are newer MB like C9 compatible with this TCON? or whole set of C9 MB+TCON+PWR will work with this panel?
    Thanks in advance
    Last edited by shaileshpandit; 08-20-2020, 07:10 PM. Reason: Title - added missing brand name
  • shaileshpandit
    • Aug 2020
    • 5
    • India
    Re: OLED55B6 - screen goes blank intermittently sound keeps on
    Forgot to mention it has some burn in also
    • Diah
      • Feb 2013
      • 6614
      put the set in service meni IN_START and keep it on it for long time... see if the screen will turn off or not.... search after IN_START IN_STOP how to access at this forum
      • shaileshpandit
        • Aug 2020
        • 5
        • India
        Thanks Diah, will let you know the outcome when I check..
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • Chrissygizmo
          Panasonic TX-48CX350B backlights but white screen , blank screen
          by Chrissygizmo
          Hi all, I’ve got a problem I hope someone can help me fixi.
          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
          01-11-2025, 03:18 PM
        • kotel studios
          Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
          by kotel studios
          Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
          State I got it in:
          Squealing from the PSU
          After logo I get a blank screen
          After 10 seconds of having a blank display w/ backlight the TV dies
          Give it 7-10ish seconds again and it starts to bootloop.
          What I did so far:
          Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
          Checked all voltage rails:
          5VSB - 4.8V
          AMP+13V - 14.4V
          13V - 12.98V (in manual 12V)...
          09-21-2025, 02:00 AM
        • dicky96
          HP Elitebook Screen blank - backlights but no image
          by dicky96
          Hi guys
          I'm trying to fix this laptop screen
          Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
          OK so I have the original screen which works but has lines across the bottom quarter of the screen
          I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
          04-28-2021, 07:30 AM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
