LG 42LW5500 strange problem
  • nomoresonys
    • 12276
    • U.S.
    Re: LG 42LW5500 strange problem
    I haven't had one with that problem lately but would heat it, just to confirm that it was the issue, that's after testing about everything else and was pretty sure that was the problem, best fix is to send the board to someone who will reball or replace the chip I suppose.
    • diif
      • Feb 2014
      • 6978
      • England
      Originally posted by clabr
      Thanks for the answer.
      Ok, I will look but I am also looking from answers in here to understand what is better and normal
      On youtube I could posibly find maybe untrue unreal even stupid things.
      Also found here in forum a post https://www.badcaps.net/forum/showth...68717&p=817319
      where someone was saying to heat at 350C ? (exactly for this bga chip)
      What is that about?
      350c will be the numbers on the display of the hot air station, its not the temperature at the board which will be lower.
      I have my hot air set to about 380c for rework.
      In order to reduce thermal shock the whole board needs heating to around 100c before adding extra heat to the processor area to carry out the reflow. Whilst I use a proper rework station the advice of holding the board over a gas stove for preheating is sage.
      • Malva
        Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
        by Malva
        I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
        Mainboard model: EAX65684604
        PCB marking: EBT62954607
        SPI chip: Winbond W25X20CLNIG Problem description:
        Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
        After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
        • I bought another
        06-25-2025, 02:07 PM
      • micsa84
        Mainboard problem Laptop Lenovo Ideapad 3 15ada05
        by micsa84
        Hello! I have a problem with a mainboard from a Lenovo Ideapad 3 15ada05.
        The problem is that the cooling fan is always on full speed, It doesn't recognize the battery and it is not charging it and the keyboard has only partial functionality, many of the keys don't work.
        I tried a new bios update but that didn't changed anything.
        What could be the problem with it?
        08-15-2023, 10:46 AM
        HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
        This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
        09-12-2024, 02:20 PM
      • stylishconsultant
        un60j620dafxza - Samsung No Display Problem
        by stylishconsultant
        Hi All,
        Need help.
        I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
        So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
        problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
        might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
        09-04-2024, 03:26 AM
      • vabea
        Asus X550LD Image problem
        by vabea
        Hello i have this notebook Asus X550ld they work normal but the image appears with interference (like video attach) i have try, New lcd and a new cable, but unsuccessful if i connect to a external monitor the imagem in the external monitor is normal without interference, any help?
        Thanks...
        04-07-2025, 08:33 AM
