Kogan KALED40AF7000STA service menu code
  • japlytic
    • Oct 2005
    • 2086
    I am after a code (entered with a remote control) to enter the Service Menu of a Kogan KALED40AF7000STA TV (already tried MENU-2-0-0-8).
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Kogan KALED40AF7000STA service menu code
    Try Menu 1147
    • japlytic
      • Oct 2005
      • 2086
      Tried MENU-1-1-4-7 without any luck.
        LCD LED TV Service Menu Codes
        ALL LCD LED TV SERVICE MENU CODES
        Service Menu Code with Board Name
        China Universal Board / Jumper Board Service Menu Code
        Changhong Ruba Service Menu Code
        Ecostar LED TV Service Menu Code
        Orient LED TV Service Menu Code
        Haier LED TV Service Menu Code
        TCL LED TV Service Menu Code
        Samsung LED TV Service Menu Code
        LG LED TV Service Menu Code
        Videocon LED TV Service Menu Code
        Supra LED TV Service Menu Code
        Toshiba LED TV Service Menu Code
        Symphony LED TV Service Menu Code
        Veste/ LED TV Service Menu Code...
        10-31-2024, 03:58 AM
      • Robby-Gr
        TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
        by Robby-Gr
        I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
        However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
        The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
        Additional issues:...
        09-27-2025, 12:02 AM
      • ARGO
        Vizio service menu code
        by ARGO
        There are a lot of different codes on internet but they doesn't work for all modern Vizio TVs.
        Here is tested code to enter service menu (factory menu), tested by me on D-series and P-series:
        MENU-1-9-9-9-Return.
        (Retun is a button with round arrow on remote)
        Overall the menu is useless because it doesn't allow to change panel and LVDS settings...
        If anybody knows any other codes for Vizio, post it here, please.
        By the way, Philips TVs uses the same main boards with same service menu access code......
        06-10-2020, 08:16 PM
      • tusiime
        How to access Vizio m652i-b2 service menu
        by tusiime
        The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
        So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
        Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
        09-15-2023, 09:57 AM
      • intercepter
        JVC LT-32CA120 service menu
        by intercepter
        I have JVC LT-32CA120
        Board:Vestel 17MB171
        I need rotate screen.It is possible in service menu and how to enter service menu?
        Thanks.
        12-10-2024, 10:29 AM
