medion MD31505 BE(vestel service mode) Distortion problem moving element
  • alessa
    • May 2020
    • 7
    • Belgique
    I noticed a problem,
    There is a distrtion around the moving elements due to the movement interpolation (soap opera effect) which is not very well managed.
    my problem is not the soap effect which doesn't bother me at all, it's just this kind of pixel / distortion effect around moving objects or actors. I ask this question because I think it could be adjusted via a service menu or firmware.
    I managed to access the service menu and I do not really see what to do to improve the thing.
    I find it quite disappointing coming from a television from 2020 and which despite this produces a very beautiful image.
    I hope there is a solution to resolve this problem.
    Thanks 😉
    Model: MD31505 BE
    • 12323
    • U.S.
    Re: medion MD31505 BE(vestel service mode) Distortion problem moving element
    Maybe try in regular menu>picture settings>advanced settings>turn off dynamic contrast, you can set the backlights there too, I wouldn't set it to more than 50, to try to extend backlight life.
    • alessa
      • May 2020
      • 7
      • Belgique
      Thank you.
      The dinamic contrast is on "light", I will test on "deactivate".
      For the backlight settings I have nothing, just the one for the brightness which is set to 44.
      Otherwise, I have a setting which is "micro dimming" and which is set to "low".
      • alessa
        • May 2020
        • 7
        • Belgique
        I received an update from tv yesterday, but the problem was already present before.
        Do you think that if this update would have solved the problem, a factory restore would be advised so that the update is well implemented?
        • petehall347
          • Jan 2015
          • 4451
          • United Kingdom
          it should be under warranty .
          • alessa
            • May 2020
            • 7
            • Belgique
            Yes of course, but the television works very well in 99% of the cases, but as written above, this occurs only when the image has sudden movement. Please note, I am using a beelink gt1 mini Android tv box with the AFRD program added for films in 24hz or 50hz or 60hz.
              • 12323
              • U.S.
              Is the problem still there if you are just using a tv antenna or using other than the beelink?
              • alessa
                • May 2020
                • 7
                • Belgique
                I have yet to test, I will. but if I put the image in "games" or "sport" mode I no longer have a problem, but all the graphics options are disabled to have a better screen response time, like on all TVs.
                But on the other TVs I don't have the impression of having seen it's small distortion on the screen in cinema or other mode.
                • alessa
                  • May 2020
                  • 7
                  • Belgique
                  https://gofile.io/?c=HRLL2o
                  Vidéo of the problem
                    LCD LED TV Service Menu Codes
                    ALL LCD LED TV SERVICE MENU CODES
                    Service Menu Code with Board Name
                    China Universal Board / Jumper Board Service Menu Code
                    Changhong Ruba Service Menu Code
                    Ecostar LED TV Service Menu Code
                    Orient LED TV Service Menu Code
                    Haier LED TV Service Menu Code
                    TCL LED TV Service Menu Code
                    Samsung LED TV Service Menu Code
                    LG LED TV Service Menu Code
                    Videocon LED TV Service Menu Code
                    Supra LED TV Service Menu Code
                    Toshiba LED TV Service Menu Code
                    Symphony LED TV Service Menu Code
                    Veste/ LED TV Service Menu Code...
                    10-31-2024, 03:58 AM
                  • AustinCER
                    Dell XPS 8940 | Manufacturing Mode? | No Service Tag
                    by AustinCER
                    Hello, I currently have a Dell XPS 8940 in our office for repair.
                    Service Tag: HG1Y673
                    The most recent BIOS is pictured below -- being available as an .exe on Dell website.
                    Needed a new motherboard due to power surge. The motherboard replacement was installed and upon power up it was booting to a display message - Manufacturing Mode Active -
                    Have not dealt with this issue before or what the proper steps are. I booted to the BIOS and manually entered the Service Tag, but upon each reboot -- the service tag is wiped and shows the Manufacturing Mode display message,...
                    07-15-2025, 05:28 PM
                    Acer Aspire A317-53-32Z4 + Extended Service Plans Notebook 3 Specification for Upgrade or Repair
                    This specification for the Acer Aspire A317-53-32Z4 + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-53-32Z4 + Extended Service Plans boardview and A317-53-32Z4 + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                    09-07-2024, 02:20 AM
                    Acer Aspire A315-58-37NX + Extended Service Plans Notebook 3 Specification for Upgrade or Repair
                    This specification for the Acer Aspire A315-58-37NX + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A315-58-37NX + Extended Service Plans boardview and A315-58-37NX + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                    Acer Aspire A315-58-57ZP + Extended Service Plans Notebook 3 Specification for Upgrade or Repair
                    This specification for the Acer Aspire A315-58-57ZP + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A315-58-57ZP + Extended Service Plans boardview and A315-58-57ZP + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
