47LW6500 Debug Help - Power Board or Mainboard?
    Re: 47LW6500 Debug Help - Power Board or Mainboard?
    Originally posted by budm View Post
    The MICOM is not sending the control signal for this section of the circuit beside the DRV circuit.
    Thank you for confirming this. I was searching online for a replacement board, but was not able to find any... so I think my options are either baking it or trying a mail in board repair service. Has anyone used one of these services or know a trusted one?
      One there, 72 bucks seems a little high to me? BUT they don't seem to be readily available so might be the best bet:https://www.tvpartstoday.com/EBT6139...bt61399411.htm
        Does not seem to be quite exact the one I have:
        EAX63969204(0) vs EAX63969205(0)
        EBR73358205 vs EBR74235304
          Guess that's a good question, I matched it up by part number LG EBT61399411.
            What is your full panel number? it's on the metal chassis someplace.
              Not sure which one is the correct number... but here is everything:
              LC470EUF
              (SD)(F3)
              470AAP6K0013Y K31B
              LIGHT GUIDE: >PMMA<
              6091L-1851A 110928 PNL J7519UHHWNLP2AAZ1851A1GB0
                Yes it was a match, looks like it's gone tho.
                  How did you figure out if it was a match or not? Just in case others show up I'll know how to check if they can be compatible even if having different numbers...
                    Key is to match your service code on the back cover of the tv, it is 47LW6500-UA.AUSYLUR correct?
                      Yes, the service code on the back cover is 47LW6500-UA.AUSYLUR as well as on a sticker on the main board that includes the different number EBR74235304.
                        Yes, certain numbers can be different, usually your good to go when you match the service code.
                          Now it says one in stock again.
                            Thank you all! Ordered it, hopefully it will work. Will keep you posted.
