47LW6500 Debug Help - Power Board or Mainboard?
  • dannysporea
    • Apr 2020
    • 17
    Re: 47LW6500 Debug Help - Power Board or Mainboard?
    Originally posted by budm
    The MICOM is not sending the control signal for this section of the circuit beside the DRV circuit.
    Thank you for confirming this. I was searching online for a replacement board, but was not able to find any... so I think my options are either baking it or trying a mail in board repair service. Has anyone used one of these services or know a trusted one?
      • 12192
      • U.S.
      One there, 72 bucks seems a little high to me? BUT they don't seem to be readily available so might be the best bet:https://www.tvpartstoday.com/EBT6139...bt61399411.htm
      • dannysporea
        • Apr 2020
        • 17
        Does not seem to be quite exact the one I have:
        EAX63969204(0) vs EAX63969205(0)
        EBR73358205 vs EBR74235304
          • 12192
          • U.S.
          Guess that's a good question, I matched it up by part number LG EBT61399411.
            • 12192
            • U.S.
            What is your full panel number? it's on the metal chassis someplace.
            • dannysporea
              • Apr 2020
              • 17
              Not sure which one is the correct number... but here is everything:
              LC470EUF
              (SD)(F3)
              470AAP6K0013Y K31B
              LIGHT GUIDE: >PMMA<
              6091L-1851A 110928 PNL J7519UHHWNLP2AAZ1851A1GB0
                • 12192
                • U.S.
                #27
                Yes it was a match, looks like it's gone tho.
                • dannysporea
                  • Apr 2020
                  • 17
                  How did you figure out if it was a match or not? Just in case others show up I'll know how to check if they can be compatible even if having different numbers...
                    • 12192
                    • U.S.
                    #29
                    Key is to match your service code on the back cover of the tv, it is 47LW6500-UA.AUSYLUR correct?
                    • dannysporea
                      • Apr 2020
                      • 17
                      Yes, the service code on the back cover is 47LW6500-UA.AUSYLUR as well as on a sticker on the main board that includes the different number EBR74235304.
                        • 12192
                        • U.S.
                        #31
                        Yes, certain numbers can be different, usually your good to go when you match the service code.
                          • 12192
                          • U.S.
                          #32
                          Now it says one in stock again.
                          • dannysporea
                            • Apr 2020
                            • 17
                            Thank you all! Ordered it, hopefully it will work. Will keep you posted.
                            • DynaxSC
                              MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
                              by DynaxSC
                              Hi Folks
                              I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
                              Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
                              09-29-2024, 04:27 PM
                            • Alain Renteria
                              LG OLED77G2PUA Not Powering On After Storm
                              by Alain Renteria
                              Got it for free on marketplace because it stopped working after a storm.
                              When I began troubleshooting the power supply, I fried 2 fuses and a mosfet by shorting 2 pins on accident, but I've replaced those components.
                              The tv had a soundbar connected, which was also killed by the storm. On the tv side I found a transistor shorted on the hdmi 2 (arc) and a lot of capacitors shorted on the main board.
                              Disconnecting and reconnecting the psu to main board cable, while still being connected to 120 V AC, would wake things up, such as a red light from the optical...
                              11-25-2024, 11:11 PM
                            • SS454
                              vizio e650i-a2 backlight flashes then turns off
                              by SS454
                              vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                              panel: au optronics T650HVN05.4
                              72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                              link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                              Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                              https://www.shopjimmy.com/vizio-56-0...-power-supply/
                              Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                              08-20-2020, 03:57 PM
                            • DominanceINC
                              MSI Pro Z790-P Wifi 1missing CPU pins
                              by DominanceINC
                              I am a new forum member. I found a broken MSI motherboard with lot of problems. The other problems need schematic. Because, the missing parts what were breaking down with screwdriver and pliers at a standoff.
                              So, its actual problem is a missing Vcore and Gnd pins in the CPU socket. My question is that, can it be used safely without these two pins? Only for testing at first, while the other problems will be solved. I would wish repair them later.
                              The other spots are thermal phaste, because, the under educated installer of the CPU did wipe the contacts of the...
                              07-21-2025, 05:38 AM
                            • ajgae
                              HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
                              by ajgae
                              Hi everyone!
                              First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
                              03-06-2025, 09:53 AM
